Philip Imbrogno
Elephant Trunk Nebula
f10 or f6.3 - newbie needs help!
Started by bish, 10/23/2004 11:14PM
Posted 10/23/2004 11:14PM Opening Post
OK, I've decided to move up from my ETX90EC to a "classic" LX200 8". My confusion is regarding the choice between f10 and f6.3 ... now I understand what the numbers mean, but I'm interested in what more experienced users have to say about the issue. The Meade book is far to vague on the issue. It states a 60/40 split between sales of the f10 and f6.3 but this is not supported by the adverisements for used units where the vast majority seem to be f10. They also state that if you are confused, don't worry... you'll be happy with either :S (never trust anyone who is trying to get you to part with your money)
My usage will not be specialized or specific... as a relative novice I'll be looking all over the place... moon, planets and deep sky. I will be attempting to do some CCD imaging, probably with a mid-range SAC unit. Here, I know, the faster lens will be advantageous as far as exposure times are concerned.
So, in simple terms, what are the practical concerns here. Sorry if this issue has been done to death.
By the way, I've opted for the LX200 8" as a "logical" upgrade to my ETX90. I know that there are other options out there, but I'm happy with Meade... and I know that statement in itself could start a shooting war wink
Cheers
Peter
Posted 10/23/2004 11:29PM #1
Well. I only had one chance to view through one of Meade's F6.3 scopes. This was a long time back. The numbers they tout--60/40 would seem worng to me. I dont know of too many people with the F6.3 version. But if thats the numbers they gave you, then perhaps it is correct.
The problems I see with these is that SCT's already have a relatively huge central obstruction. Going to F6.3 only increases it more. Which lowers contrast. In the sample I viewed through, this was evident.
Shortly after Meade introduced these scopes, Celestron I believe introduced the F6.3 reducer. Later Meade also started selling them. That is the way I think it happened, been so long now, hard to remember. All I remember is that initially Meade was using some silly marketing. Saying that images in their scopes were brighter than competing SCT's because they were F6.3. Celestron had to advertise and denounce this saying that in any 8" scope at the same power, the images will be the same brightness.
At any rate I would go with an F10 SCT. Then pick up an F6.3 Reducer/Corrector. For CCD work, because of their inherent small chips, the Reducer works great. Now, for full film illumination of 35mm, there is I believe a problem with vignetting. Again, I am not an expert, so you might research that also.
Hopefully one of the CCD and film guys here can chime in. If it were me I would go for the more versatile F10 and get the reducer also.
Posted 10/23/2004 11:41PM #2
Peter,
I own the F/10 model and use it primarily for CCD use, and Mostly with the 6.3 Focal reducer. However, I prefer the f/10 for its versatility, as I can go from f/10 to f/6.3 to f/3.3 with focal reducers. With the f/6.3 you would need a barlow to get to f/10. It really is up to you and how you want to use it. I like to think of it like this, with 6.3 you will get a wider field of view from the get go. But to zoom into those planets you will have to use a barlow, and higher magnification eyepiece's and will never reach the potential of the f/10 unit. The only downside is the wide field of the f/10 can only be reduced to f/6.3 for visual use, and the f/6.3 unit will go to around f/4.5 with the f/6.3 reducer.
Personally I would and did go with the f/10 unit.
Wayne
[COLOR="Blue"]Wayne[/COLOR] 8O
_________________________________________________________
Never stop looking up!!
Takahashi TAO-130on a Losmandy G-11 Gemini 4
Williams Optics Zenithstar 105 APO on a G-8 Gemini 4 (Field setup)
ST2000XM with CFW10/L-R-G-B-Ha-SII-OIII filters
Home Built backyard Observatory
Understanding Wife.. 8)
Posted 10/24/2004 02:36PM #3
Peter,
I've owned an LX200 10" f6.3 for three years now. It is a wonderful widefield scope as far a SCT's go. The problem occurs (as others have stated) when using the scope for planetary viewing or webcam imaging.
At f6.3, I need to use a 4x Powermate to TRY to produce the
images of f10 other SCT owners.
As for imaging Deep Sky objects, I tend to use a ED refractor, 300D combination. The images tend to be of much higher quality before processing. The "cropping " tool in all image editing software is a great thing smile
IMHO go for the f10 scope (and Digital Rebel) you'll be happy with your choice.
Regards,
Tom T
ttolla's attachment for post 84156
Tom T.
Guilford, CT smile
