Iris Nebula
How much Dew Heater heat???
Started by Midnight Sun, 12/18/2003 02:43AM
Posted 12/18/2003 02:43AM Opening Post
Was wondering if too much heat generated by my 8" Heater strap snugged around my Objective Lens can introduce un-wanted thermals inside the OTA. I have a C8. I usually turn the controller on high to remove the Dew on the lens, then slowly turn down, watching to see if Dew starts to return.. there is no fan in the OTA like at the bottom of my Mac/Newt. Any thoughts on this? thanks, JM
Posted 12/18/2003 03:04AM #1
Yes, too much heat is definitly bad. I put the
heater on its lowest setting as soon as I
put the scope outside. If I see any traces
of dew (usually a slight haze can be seen first)
I turn up the heat a little bit. A dewcap
also helps alot.
Posted 12/18/2003 03:52AM #2
It's doubtful heat around the corrector plate could cause internal air currents. There are going to be a bunch anyway, which I discovered in testing a laser collimator which projects an image through the scope to a target. Internal air currents are very noticeable.
Posted 12/18/2003 06:05PM #3
John, I use Ron Keating's DewBuster and usually set it to around +4 or +5 degrees F. above ambient (it is temperature controlled, measuring the ambient temperature). I have an insulated dewshield over it on my 10" SCT and it keeps it above the dewpoint and dry as bone all night (here in southern Louisiana near the Gulf, where we use umbrellas to cover from the dewfall). And I don't have to apply any more heat than is necessary to keep it dry. It sounds like you have Kendrick type of controller and I have heard that sometimes people crank theirs up early in the session and then taper it down later. This seems to have some success. It really depends upon the temperature swings you have, which is one real plus for the DewBuster, since it automatically adjusts to such swings. One real key however, is to not wait till the dew forms before turning on your dew heaters. Turn it on from the beginning of the session and keep your optics dry all night long. That way you shouldn't have to crank it up in the beginning, which should make for more efficient use of your battery power (if you are running on batteries). Best wishes, David Moody
