Jay Messeroff
Lunar & Solar Transits
how to know the perfect telescope..
Started by paulsky, 09/15/2007 03:17PM
Posted 09/15/2007 03:17PM Opening Post
Hello,
I like know how I can understand the perfect telescope: refractor,refractor or compound....aperture....and focal lenght...for my site.I am visual observer and my observation site is the garden of my house.
my site is semi-rural with great humidity percentage.
thanks for your opinion,advices.
paulo
Posted 09/15/2007 03:41PM | Edited 09/15/2007 03:42PM #1
Paulo
I'm sure you will get a great variety of recommendations on this one, and rightfully so. Perfection is in the eyes of the beholder and user. After trying quite a variety of scopes, my perfect visual setup from a well light polluted suburb is:
-Tak FS-128 (relatively light, quick cooldown, excellent optics, good resolution)
-ASGT G5 Mount (relatively light, stable for OTA, quick alignment, accurate Go-To and tracking)
-Variety of eyepieces (3.8, 5, 7.5, 35mm Ultrascopics, 13mm Type 6 Nagler, others. Tak 1-1/4" diagonal.)
-Adjustible viewing seat.
-Supportive wife (optional for some, but not for me)
The main targets are planetary, lunar, brighter deep sky, and nebula with the right filter.
I'm sure you will get plenty of alternate suggestions, but this is mine. Total cost between $4,000 to $5,000 using Astromart wisely, including Astromart "Green" support.
Steven Jindra
Posted 09/15/2007 04:17PM #2
Sorry, there ain't so such thing as a "perfect" telescope anymore than there's a perfect anything else. There are some very good telescopes, but they ain't perfect. 8)
Uncle Rod
Time on your hands?
Posted 09/15/2007 05:53PM | Edited 09/15/2007 05:57PM #3
Hi Paulo,
You ask the same question I have been asking. In order to answer it for myself, I have gone through many different telescopes including refractors,reflectors and compound along with many different apertures (60mm to 12.5" so far)and focal lengths. All have had something to offer and I realize now that I have to first define what I want to use the scope for. My preference is visual with a focus on lunar, planetary and globular clusters since I live near a major city and do not have dark skies. For me the best scope is one I can easily set up and use by myself and that gives the sharpest, most detailed images possible. At the moment that scope is a largeish TMB 175 APO but I also have a few small scopes and a 12.5" Portaball.
Since I live by the ocean, dewing is an issue. Refractors and compound scopes all struggle with dew and the anti-dew heaters, as good as they are, do not always keep up. My newtonians do not fall prey to dew as easily though it has happened once or twice. If you can leave your main scope set up all of the time, you will not need a "quick look" scope. If you do not plan to take a scope with you on trips, you may not need a small scope at all. If I were you, I would look through as many different scopes and styles as possible and then decide. If I could have only one scope, it would be the 12.5" Portaball as it does everything well and is optically excellent when seeing is good or better. If you think it would be of help, I have kept notes on most scopes I have owned and would be glad to send them to you. My e-mail is:
[email protected]
When all is said and done, Vahe is right- the perfect scope will always be the one you don't have or can not afford. For me that perfect scope is a 8" to 10" APO which would be larger than I can handle alone, require a huge mount and permanent structure in order to get much use. Not quite perfect after all!!!
Posted 09/17/2007 07:10PM #4
>>>Hello,
Paulo: Others have said there is no perfect telescope and in many ways I agree. But I think there is another way to look at this... Are you a "cup half full" or a "cup half empty" sort of observer. If you are a cup half full sort then:
The perfect telescope is the one you are looking through... if you are happy and satified with the experience then it is the perfect telescope...
On the other hand, if you are looking through the eyepiece and anxious for something "better" whatever that might be, sharper, brighter, contrastier, then something is wrong.
So, in my view, the "perfect telescope" is one that allows me to have a "perfect experience" and I have a few of those scopes.
