Iris Nebula
It had to happen..bifocals
Started by ivanong, 01/25/2009 08:16PM
Posted 01/25/2009 08:16PM Opening Post
Hi, well, I resisted long enough but it looks like bifocals are in the future for me! Question: I have astigmatism, and observe frequently with eye glasses on. I have been recommended the graduated bifocals (not sure what they exactly are but I assume it will not have that distinct half-moons on the lower part of the eye glass lens)...do any of you who wear them find them a hindrance to observing? If the far sight portion is on top, does that require peering from the top side at some angle? In astronomy you can easily run into imperfections and distortions from eye glass lens itself. Your thoughts are appreciated.
Thanks
Ivan
Posted 01/25/2009 10:04PM | Edited 01/25/2009 10:06PM #1
Thanks
Ivan
Ivan:
I believe that your optometrist has recommended "progressive lens." Several years ago, my optometrist also recommended these for me along with the guaranty that if I did not like them, they could be replaced with standard bifocals.
I did give them a try for 30 days but I found them unsatisfactory as they produced a great deal of edge distortion. The edge showed what seemed to be a great deal of probably pincushion distortion. In certain situations, I found this very disturbing, walking down a super market isle produced the sensation that the shelves were folding in on me, a fisheye effect.
I turned them in and have been enjoying standard bifocals ever since.
I know that there are plenty of people who do use these lenses without problem but I also know there are a significant number who shared my reaction so I would hope that your optometrist would offer you that same guaranty.
I suffer from presbyopia, not much astigmatism, I just need both reading glasses and mild distance glasses to get the sharpest views, standard bifocals handle the job quite nicely and at night, they are sharp across the field of view.
Posted 01/26/2009 12:12AM | Edited 01/26/2009 12:20AM #2
Thanks
Ivan
Plain old regular line bifocals work very well. You know exactly were you're looking through at the ep.
On a side note, if you spend time outdoors, then consider glass lenses. Small light weight glass. Small = fog up less, and glass = clean far easier.
Please note that glass lenses and volcano top ep's do not play well together. Plastic lenses work better if one bumps metal on ep's, or finders.
Posted 01/26/2009 04:46PM #3
I initially tried "progressives". The distortion that Jon talks about was disturbing at first, but I got used to it pretty quickly. I did switch to regular bifocals, though, because I found it easier when I knew just what part of the lense I was observing through. With the progressives, the correction varies, so shifting your head just a little can change the focus. I am pretty nearsighted, and I usually observe with my glasses on because it's just a pain to keep removing them and replacing them to read charts, etc. And, if I am observing with others, it leaves the focus close to 20-20. I also don't fog the eyepiece when I wear my glasses. I usually only take my glasses off for eyepieces that give higher powers or have a narrower field of view or short eye relief.
Posted 01/27/2009 05:17PM #4
My first eyeglasses were progressive lenses and it was a disturbing period of getting used to them that almost made me give 'em up. I have mild astigmatism in one eye and moderate astigmatism in the other. So I've gotta wear them at the EP now. :C
I'm on my third set and have been having no problems observing with them. They don't seem to affect my view through the EP. smile
My second pair I bought at a large optical company and have learned not to ever go to such places. The third pair has the best correction I've ever had--proof that staying away from the big guys is good advice.
Gerald
Posted 01/28/2009 01:26AM #5
I've had both progressives and bifocals, and found both unacceptable for observing. The faults of progressives have been dealt with above (basically, they're only sharp on axis)--but I found the reading portion of the bifocals tended to intrude into the lower part of a widefield view (maybe because I favored small lenses). So for observing I stuck with straight distance glasses, UNTIL I got dioptrx. Now I use that on anything over 11mm focal length (typically, 2mm exit pupil). I have to say, I never had a view through a widefield like my 26T5, wearing glasses of any kind, that came close to the beauty I enjoy routinely now with the dioptrx. My astigmatism runs around 2 diopters, for comparison's sake.
--george
George Golitzin
Posted 01/28/2009 03:34PM #6
Ok, I can't leave this topic alone. I bet I'm the only person responding to this topic who is not yet to the bifocal/progressive lens phase of my life. However, I'm an optometrist who prescribes them every day.
It's interesting reading all the other responses. I get so caught up in "my side" of the business, it's easy to lose site of the patient's perspective which can be very important!
If it were me, I would get the progressives in either plastic or polycarbonate material with a QUALTY scratch or anti-glare coating. My office sells lenses with Crizal anti-reflective / anti-scratch coating and we offer a 2 year, unlimited replacement on the lenses if they do scratch. You'll most likely find that getting used to the progressives is a pain for a week or so, then you love them.
I would spend the extra $$ for a 2nd pair of glasses (nothing too expensive, just your basic frame and plastic lens) without the progressives and use those for observing. There are times when twisting or turning your body to reach an eye piece makes it impossible to look through the center of the glasses. And with a progressive, if you're not looking through the distance portion, your eye piece will not be clear. Think about it: you can buy a pair of glasses just for viewing and spend less than you've probably spent on some of your eye pieces...
Posted 01/29/2009 09:39PM #7
Hi Ivan.
I've worn trifocals for a number of years and have found them OK for observing. They're not graduated and sometimes the "line" separating the different portions gets in the way. But then all I do is move my head a little and the problem disappears. I would expect bifocals to be OK, too.
John
