Iris Nebula
Ivan-80mm on lx200
Started by ewaddell, 01/30/2004 04:31PM
Posted 01/30/2004 04:31PM Opening Post
Ivan
I just recieved my 80mmED and have mounted it on the Lx200 8". I have the slide bar balance system from Meade. This does not seem to do the trick.It will balance in a horizontal position but move it either way 30 degrees and it becomes heavy on that side. Suggestions?
Ed Waddell
Posted 01/30/2004 04:52PM #1
Edward, I do not currently have the 80ED, but I have an ST-80 mounted on top of my 10" LX-200GPS...
IS your scope Nose Heavy or Back Heavy?
I have Scopestuff's rails & weights on my scope to help on the balancing issue...
The ST-80 is mounted on (2) 3-point rings, and these are mounted on a rail, so that I can slide the scope until I find the balance point.
I'm not sure if you are using your scope on a wedge (equatorial setup) or Alt-Az..., I'm personally using mine Alt-Az, which simplifies the balancing issue.
As a note, I have the Meade Aluminum Dew Shield (makes scope NOSE HEAVY) and I use the Microfocuser/ 2" TV Diagonal + 2" eyepieces (to help balance the back side).
If I level my scope, and release the clutch, the scope stays perfectly put...
You "could" need more weights on your balance system to compensate...
I hope some of these ideas help you...
Ivan
smile
