Ruben Tommasi
Andromeda Galaxy (M31)
Lumicon Halpha any good?
Started by cruel_world, 02/06/2003 11:42PM
Posted 02/06/2003 11:42PM Opening Post
I have the oprotunity to buy one but I dont know much else about it including Wavelenght. are they all the same?
Posted 02/08/2003 05:48PM #1
The lumicon h-alpha is a prominence viewer. The bandpass is somewhere along the line of 1.5 angstroms. A wide bandpass will be good at showing prominences, but not surface detail. The lower the bandpass, the higher the detail that can be seen. To see surface detail, <1 angstrom is pretty much the limit. If you really want a premium solar filter that will knock your socks off, Pass on the lumicon and save up for something under 1 angstrom (a coronado 40mm solarmax is a great deal IMHO). You won't be dissapointed.
Posted 12/30/2003 03:41PM #2
I had A Lumicon H-alpha filter. It is recomended to use it on a focal length 2000mmm of greater. I used it on a Meade 10" scope with a focal length of 2500mm. It gave acceptable views of the prominences but no detail on the surface. Also the two biggest complains I had were that I could not get a full disc image in the eyepiece and the background sky was always pink. I went as far as to flock the inside of my scope thinking that would help cut down on stray light but the sky was still pink. Now if you can live with only seeing a partial solar disc and the background sky not being black, the Lumicon filter shows prominences very well. I included a photo taken on my first day to show you the image you can have. Mind you it has been run through photo shop. My advise to you is to look into the new Coronado PST. If it is half as good as the buzz surrounding it, for $499.00 it will be the hot item of 2004. I hope this helps you. It is only my $.02 worth
Vince's attachment for post 74571
