LXD55 RA Gear Problem
Started by mlehere, 05/24/2003 02:40PM
Posted 05/24/2003 02:40PM Opening Post
I removed the RA motor last night to adjust the mesh of the RA gears. I noticed there was some free play in the bronze(brass?) gear on the motor side. Is this normal or is there additional work that I must do? If so, what is needed next? Should I retrain the motors after adjusting the gears?
Mike
Posted 05/24/2003 04:34PM #1
No, there should not be radial play between the gear and shaft. Many units have needed their set screws tightened up and secured with threadlocker (e.g. Loctite). Check both gears, and the Dec unit too. Yes, you must retrain after adjustments.
Lots of info available at the LXD55 Yahoo group:
http://groups.yahoo.com/group/LXD55telescopes/
