Need Crosshairs
Started by Kevin, 12/26/2009 11:07PM
Posted 12/26/2009 11:07PM Opening Post
I have received a finder that has no crosshairs. Is there an easy way to make these and where do they go. I assume on the objective side of the eye lens?
Kevin
Posted 12/26/2009 11:46PM #1
Kevin
Kevin: Those wires have to be tiny-tiny. Typically they do go he objective side at the focal plane of the eyepiece. You should be able to see where they had been glued in place.
Posted 12/27/2009 12:08AM #2
Human hair works great for cross-hairs, they were used in WW2 for bomb sights.
Posted 12/27/2009 02:26PM #3
I have used a tiny #0 machine screw. I sharpened the tip and drove it in from the side at the focal plane. This has the advantage of not needing illumination since it is so thick; the disadvantage is that it obscures about 5% of the view.
Posted 12/27/2009 04:10PM | Edited 12/27/2009 04:14PM #4
I use small strands of wire taken from stranded wire. I sampled many wires until I found the thinnest wire strand. I twisted and soldered small loops on the ends of a strand and placed it on a stretcher made from an old coat hanger. The strand is laid across the field stop and some weight is placed on the stretcher to pull the strand tight and I then place a drop of super glue at each end of the strand. When the glue cures I trim the ends with a razor knife. The cross-hairs are a little thicker than hair or spider web but I like that because it makes them easier to see agaainst a dark sky.
Hope this gives you some ideas.
John
CCD-Freak
John
CCD-Freak
WD5IKX
Posted 12/29/2009 10:06PM #5
You do not need them. If you were observing Jupiter you should easily be able to discern when a feature was on the planets' Central Meridian (midway across planets' disc) & so likewise you should easily be able to discern where the center of your field of view IS without use of crosshairs; slight de-centering is obvious. A low-power eyepiece in the main telescope will then enable centering its' view for more powerful eyepieces in turn. I find crosshairs distracting & I've not used crosshairs in my finders for over half a Century with no aiming slowdown or inaccuracy whatsoever.
