Nightscape CCD camera
Started by JJM, 01/25/2012 05:55PM
Posted 01/25/2012 05:55PM | Edited 01/26/2012 07:26PM Opening Post
This is by no means an extensive review, but here are a few words on my initial experiences with the Celestron Nightscape CCD camera and its associated software. Nightscape is a color, one-shot camera likely intended for folks who are considering a DSLR for astro imaging. The camera is made in Canada, probably by the same company that manufactures similar products for the big astro resellers. Build quality appears good and the unit has a solid feel with no unfinished edges or cheap hardware. It does not include an AC power adapter and instead has a standard 12V "cigarette lighter" plug and cord. I kluged an adapter and used a 12V power supply to run the camera. Cooling for the sensor is set-point regulated, as much as 20C below ambient.
The sensor is a KAI-10100, ~ ten megapixels, and at 4.75 microns, the small pixels are probably best suited for use at shorter focal lengths (color binning is supported 2x2 and 4x4 for longer FLs). This sensor has the same linear measurements as the KAF-8300 (22 mm diagonal), and the same well depth and dynamic range. Even though it uses an interline transfer chip capable of electronic exposures, the Nightscape has a built-in mechanical shutter that sets exposures from one millisecond to 24 hours. The chamber window is AR coated and unlike typical DSLRs, includes an IR block that doesn't attenuate red emission lines. Celestron states the camera has a "full frame buffer", and some discussions I've seen on the web imply that this memory buffer allows imaging to continue during downloads. If this feature exists, it is not supported in the current AFX software, and I noted a roughly seven-second delay between subs while the camera downloaded data. Perhaps the frame buffer is used to facilitate readout/binning of color data, but I saw no evidence that it speeds up acquisition.
A key selling point emphasized by Celestron is ease of use, and in that regard this product stands out from the crowd. Most low-end cameras ship with "lite" versions of MaximDL and have a steep learning curve when it comes to calibration and processing. For the Nightscape, Celestron commissioned a custom app from Diffraction Limited called AstroFX to run the camera and process images. IMO this software will make a big difference to the typical customer because it assumes the user is not a border-line-OCD astro-geek (cough, PI, cough, Maxim). The software emphasizes results over arrays of obscure functions and a litany of open windows and menus. Some bugs are there -- the software is V1.x and it crashed several times during image acquisition over the two nights I used it. Processing the resulting image and calibration files was simple and straightforward, and I encountered no glitches on that end. Compared to high-end programs, the tools and adjustments are rudimentary, and many processing settings have an "auto" option.
Here is my initial image, M45 taken from a suburban site (SQM 20.4) with a TV85 refractor at f/5.6 and a IDAS LPS-2 filter. The exposure was 20 x 3 min, unguided, and only darks were used for calibration. All data were captured and processed in AstroFX, and the "auto" settings were used for everything except the initial stretch. No, it won't cut it as an APOD submission, but the overall experience was far less involved and time consuming than a similar project using a DSLR and third-party software.
http://dl.dropbox.com/u/44791121/Nightscape_M45.jpg
Jim McSheehy
Posted 01/25/2012 07:29PM #1
Good info.
Were you using 32 or 64 bit Windows 7? I assume USB, no Firewire?
Is it Mac compatible?
Cheers.
Marc
Posted 01/25/2012 09:33PM #2
Nice pics thanks for sharing,also not bad for unguided
Pete
Posted 01/26/2012 01:55AM | Edited 01/26/2012 01:57AM #3
I am curious about this camera. It will be interesting to see some images made with longer subs. I have an Atik 383L+OSC with the KAF-8300 color CCD and I find it really does much better when you take subs longer than 10 minutes.
Please post any other images you get. Thanks for posting this.
John
CCD-Freak
John
CCD-Freak
WD5IKX
Posted 01/26/2012 04:09PM #4
Jim McSheehy said:....color binning is supported to 3x3 for longer Fls....
Are you sure of this?
I'm not aware of any OSC that can support color binning.
That's not to say that it couldn't be done or has been done behind my back.
A curious,
dan kowall
Posted 01/30/2012 06:49AM | Edited 01/30/2012 06:52AM #5
I had an opportunity to take a few more test images with the Celestron Nightscape OSC camera. These are all from ten-minute guided subs using a TV85 refractor, 0.8X reducer, and IDAS LPS-P2 filter. Conditions were not the best, with some high thin clouds and a waxing moon low in the West. I had the camera TEC set at -20C and outside of three program crashes (AstroFX still has rough edges), the session went well.
Some have asked about the color binning modes of this camera and I tried all three modes on a section of the California Nebula. In this setup with the TV85, the base resolution at 1x1 binning is about two arc seconds per pixel, which roughly matches the typical seeing. The color binning definitely "works", but some odd artifacts appear in the 4x4 image, and at 8.5 arc seconds per pixel, the stars are starting to get rather blocky.
These image data were all captured and processed (minimally) in AstroFX:
California Nebula, 2 x 10 min (to demonstrate color binning modes)
1x1:
http://db.tt/F6zjyGEZ
2x2:
http://db.tt/msMGrOga
4x4:
http://db.tt/cMLCGyjA
At 1x1 binning:
M81 M82, 5 x10 minutes:
http://db.tt/cU2Gqr3e
Rosette Nebula, 3 x 10 minutes:
http://db.tt/qIy5QebO
Jim McSheehy
