You would think after 50+ years of casual use of both reflectors and refactors choosing a new multipurpose scope to see and photograph nature would become easier. It has not. I am looking for other people's input as to what affordable scope gives the best "bang for the buck" That can be used for photography or viewing wildlife or used for Astronomy. i sold my 1980's Ultima 8 and other reflectors. My Swarovski vintage 80mm spotting scope for wild life observation is not the best to turn on the heavens or take photos. What portable choices are available for multipurpose uses? What are others using? Is this an impossible hunt?
Portable scope for BOTH Terrestrial and Celestial viewing and simple photography
Started by KBP, 03/15/2019 06:23AM
Posted 03/15/2019 06:23AM
Opening Post
Posted 03/16/2019 10:29PM
#2
Nope....not impossible. The forums here are just not all that active. Combine that with the premise you used of "affordable" and that makes it quite difficult to address. "Affordable" covers a LOT of territory depending on your definition as does leaving the size question pretty open ended with the word "portable".
I have scopes ranging from 80mm f/6 to 9" f/16 and 20" f/5 and all of them are "portable" to a varying degree.....
Tighten up your definitions of affordable and portable a bit. So far based on your intended uses I can say a refractor is your best bet along with an EQ mount that capable of tracking for imaging. Which mount would be best is very dependent on what scope is going to be on it so narrow it down some regarding your definition of affordable and portable scope wise. I will say this much there are some smaller to moderate size wise mounts available that operate in both EQ and ALT-AZ mode that have tracking which would lend themselves to both astro imaging and wildlife observing/imaging available.
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
Posted 03/17/2019 06:27AM
#3
A used Celestron C5+ or the current C5 spotter would be good choices. I have the former, my son has the latter. We both use ours for terrestrial and celestial viewing, although I don't use mine as much as I used to for celestial viewing because I have two larger scopes. For portability, the C5+ on the table-top wedge is a great choice. For celestial viewing and astrophotography, I also have the Celestron Advanced VX mount.
Posted 03/17/2019 06:52AM
#4
Thanks for all who replied to my post. Each reply has helped a lot. Any other comments or suggestion will be greatly appreciated! One comment peaked my interest about mounts and tripods. " there are some smaller to moderate size wise mounts available that operate in both EQ and ALT-AZ mode that have tracking which would lend themselves to both astro imaging and wildlife observing/imaging available."( thank you Greg Shaffer) I would love to know what these are and maybe pair them with a small scope around 127 or 150 mm in size. Moderate price is around $1500.00 or less. Not looking for a big heavy scope or major investment.
Posted 03/17/2019 07:14AM
#5
There are two that I am aware of mount wise though I am sure there are others as well.....However if you are talking about buying new there went your budget on a mount as they are both approx $1400 ea
Orion Sirius Pro AZ/German Equatorial and the Sky-Watcher AZ-EQ5
You may however be able to squeeze that down quite a bit by buying used.....
Not sure you will squeeze a 127 to 150mm scope (at least not a decent one with an ED glass lens) and a mount even used on both out of 1500 though.
Celestron C11
Monroe GA
Posted 03/17/2019 08:01PM
#6
Rich is correct in that a C5 or even a C6 would be the cheaper way in to the aperture range you are looking for....as well as portability.....
Celestron C11
Monroe GA
Posted 03/28/2019 01:19PM
#8
Hi All,
This thread was very interesting to me, so thanks to all who contributed. I don't disagree with the conclusions about a C5 on a fork or a C6 on the larger end. I wonder if a de-forked Meade ETX-125 might fit the bill and put the extra money toward a better mount ? I've been told that the money spent on a better mount up front pays dividends later.
Cheers,
Ed
Cheers,
Ed
