replacing cross hairs
Started by Jim kuhns, 05/20/2013 08:54PM
Posted 05/20/2013 08:54PM Opening Post
i have a 50mm finder scope on a cave 10" f/6 tube assembly. the cross hairs in the finder scope are broken. the old broken ones are very fine cooper wire. i have tried to super glue but the wires will not hold to the retainer ring. . has any one out there in astro. land had to replace theres in the past? any help will be appreciated.
Posted 05/21/2013 12:04AM #1
See Porter's article and diagram in "A Filar Micrometer" in Scientific American "Amateur Telecope Making" book two, pg 456 (original editions).
Refers to spider web x-hairs, but I have used similar technique with very fine copper wire and hair.
Good luck, John
Posted 05/21/2013 03:20PM #2
I made a V shaped spring loaded stretcher for the fine wire which I get from pulling single strands from a multi strand wire. The stretcher allows me to lay the strand across the ring and I apply a small amount of weight to get the crosshair strand tight then I apply the glue. When the first one is dry repeat for the other crosshair. The crosshairs may be a little wider than the origional but that makes them easier to see at night.
CCD-Freak
John
CCD-Freak
WD5IKX
