SCT and H2o
Started by Brianpope, 01/15/2005 01:55AM
Posted 01/15/2005 01:55AM Opening Post
Okay, For almost a month in cincinnati I have been trying to see our little comet. It snow stormed and then rained almost non stop. My SCT is in my shed and tonight I had clear skies. Went out collimanted first aligned second and third Found the comet, not much tial thou. It is Cold, I start to haze up, I look at the front of my sct and its condensationed up on the inside! I have never noticed this on the inside, Do I need to heat this up turn it uside down and dry it out?
Brian
Posted 01/15/2005 12:53PM #1
One does not need to remove the corrector to dry out the inside of an SCT, merely remove the visual back and the scope is open to the air.
Removing the corrector is to be avoided if at all possible and if one does it, care needs to be taken to make sure that it is marked and replaced in the position.
A good website with lots of SCT tips is Rod Mollise's. Rod is author of Choosing and Using an SCT... members.aol.com/rmollise.
jon
Posted 01/16/2005 12:41AM #2
Brian,
I remember a similar but worse situation with my SCT. I was at a star party which rained for most of the week and I had an Astrosystems bag that leaked. Well I figured this out after the rain had stopped. Needless to say I had a 3 inch puddle of water sitting on the corrector. In my case I wicked as much of the water out of the tub as I could. The rest was water vapor that had accumulated from the warm sun. I had to remove the corrector. Almost immediately after I did this the moisture was gone. Mind you that when I removed the corrector, it was a hot sunny day and the moisture just evaporated. If you have the time, I would recommend what Jon said. Just remove the visual back and place it facing up in the dryist room in your house. The moisture will disappear. It just might take a little time, but eventually the air in the tube will equalize with the air of your room.
Clear Skies and dry tubes,
Jay
Posted 01/18/2005 11:54PM #3
thanks for your input people and monday was clear... and freezing!
Posted 01/19/2005 03:24AM #4
Good thought Steve......
