Ruben Tommasi
Andromeda Galaxy (M31)
shipping an OTA
Started by rokipynes, 05/03/2004 08:36PM
Posted 05/03/2004 08:36PM Opening Post
I am about to ship an SCT to a buyer and would like the groups input. My first thoughts are to wrap the tube in several layers of bubble wrap and then pad the corners of the box with dense foam. I also thought foam at each end of the OTA would be of benefit. My intent is to get a box that is at least as big as to allow several inches on all sides and the ends. Do any of you have any experiences that you could pass along. I want this to get to the other end with both the buyer and myself satisfied.
Clear skies. Doug Smith
Posted 05/03/2004 08:46PM #1
Double Box! Do as you said and then put that box inside a second larger box filled all around with peanuts, and cram them in tight!! Then pray a lot!
Walt
Posted 05/03/2004 08:51PM #2
Doug,
You have the right idea. I've shipped SCTs many times and never had a problem. Of course, the original shipping material is usually best. If you don't have that, bubble wrap around the OTA and dense foam to isolate the whole rig from the sides of the box is good. The main thing is to make the pack job on this box nice and tight. Be sure to turn the focuser (usually clockwise) so that the primary mirror is all the way back and whatever you do, double box the whole thing. Make sure there are no loose parts--tape everthing down firmly.
Take a few quick pictures of your pack job, insure the package for the replacement value and don't sweat it once it leaves your hands.
Best wishes,
Randy
Randy Roy
Posted 05/03/2004 11:14PM #3
double box, double box, double box, double box, double box, double box, double box......................
Mark Visser
Posted 05/03/2004 11:14PM #4
Hi Doug
I was in the biz for many years and the advise the others have given is good. Bubble wrap the item with at least a few layers (more is better), then put it in a box and fill in the extra space with loose fill (peanuts)making sure you have peanuts on all sides and bottom, them over fill the top by about 1 inch or 1.5 inches, then squeeze the flaps shut so the loose fill all locks togather (this is important so the item does not giggle around and migrate to the bottom. Tape the center seam and side seams of the flaps. Now drop that box inside a larger box that that will give you at least 2 inches of room on all sides, top and bottom (If the item is heavy or very valuable a double wall box is better) and fill with loose fill and over fill. Double tape ALL seams (center and side seam of flaps).
The reason for all this is obviously is to protect the item but double boxing is about the only way you have a chance of winning a claim is there is a problem in shipment with any of the major carriers.
Hope this helps
Buck
