Telepod head question
Started by tnboy426, 04/02/2004 10:12PM
Posted 04/02/2004 10:12PM Opening Post
I have a telepod head, and want to mount it to an Orion paragon plus photo style tripod. I just got it. On the paragon tripod, after taking off the fluid pan head, there is a 1/4" 20 stud. The telepod head has a larger size hole in the middle for mounting, and a 1/4" 20 hole off to the side. I was wondering if someone out there that has run into this could share their knowledge with me and tell me if there is some way that I can mount this without having to mount the telepod head off to the side to use the 1/4" 20? Is there a part out there that I could use to mount the head into the center hole and have everything balanced better? Any help would be much appreciated.
Mike
Posted 04/02/2004 10:38PM #1
Mike,
It shouldn't be a problem to use the off-center 1/4"x20 stud with the Telepod. I used the same configuration with a TV Upswing mount that I used to have with no problems. OTOH, a photo shop may be able to provide an adapter to convert. Bogen makes one that converts from 3/8"x16 to 1/4"x20, but not vice versa.
A friend of mine has a Paragon tripod that he converted to replace the 1/4"x20 with a 3/8"x16 stud for use with a Telepod. Unfortunately I didn't look close enough or inquire what was involved, but if you're handy with tools I'm sure it's not too hard to do. Perhaps someone else has first-hand knowledge of this surgery.
Jim
Posted 04/02/2004 10:44PM #2
Hi Michael
Using the 1/4-20 will not be a problem, that is what it is there for. I've not heard of anyone ever having a balance problem used this way. I've never seen the tripod you have but maybe check to see if you can remove the 1/4-20 stud, if you can, than most camera stores should have an adapter stud.
Hope this helps
Buck
Posted 04/03/2004 05:52AM #3
Thanks for your replies Jim and Bernie. I guess it will work fine like this. It just looks a little funny off to one side like that. I'll give it a try like this, and maybe keep my eyes open for a way to do it the other way.
Thanks.
