Ruben Tommasi
Andromeda Galaxy (M31)
To all you experts!!!!!!!
Started by ricardoamador, 04/03/2004 09:23PM
Posted 04/03/2004 09:23PM Opening Post
Hello all. I finally got my meade and celestro eyepiece deal. So I tried them yesterday night. When I saw jupiter using the 2x barlow from celestron and my high power 4mm meade eyepiece I noticed I couldn't see much detail in Jupiter, it was blurry. The magnification was around 405x. Is this normal for a 8" lxd 55 schimidt newtonian??? with 830 mm focal lenght? Another question. Can I use any type of barlow in either short and long focal radio telescope or are there some that are special for some of them?
Thanks a lot.
Ricardo R. Amador
Posted 04/03/2004 09:38PM #1
Ricardo, 400x is probably the maximum your scope will reach, and that's with Great Seeing...
On a normal-good seeing day, I say about 200-300x should be pretty much as far as you'll go before you start loosing detail.
On a BAD seeing day, you'll be lucky if you can get 150x-200x, and maybe less if the "seeing" is terrible...
Barlows will work on both, long and short focal length scopes, no need for special ones for each type...
Clear skies!
Ivan
Posted 04/03/2004 11:43PM #2
Over and above all the good advise that you have received add one more; if your scope had not reached full cooldown you pretty much can expect blurry images at any power.
Vahe
Posted 04/04/2004 01:23AM #3
Ricardo ... Your optics are probably dusty / dirty. You should dismantle your scope and clean everything thoroughly.
Or not .....................
Posted 04/04/2004 01:44AM #4
Ricardo,
Ivan is right on. One additonal point can be made. The 400x is theoretical max - perfect seeing, good optics. The fact that you have a really fast scope (about a 4.1 using your numbers) means your optics break down fast. See is going to have to be great for you to get over 300x. I have an 8" f5 and have been to 400x and beyond only once or twice with it. Seeing usually doesn't allow and you and I need better seeing then most due to our short focal lengths. When you get it though, it's beautiful.
Ed
Posted 04/04/2004 04:48AM #5
Ricardo,
Local seeing conditions were probably not helping. Did it look like the 2 images here?:
http://www.tomhole.com/What%20will%20it%20Look%20Like.htm
This illustrates the effect that mother nature can have on your views. Even a $50,000 telescope is governed by mother nature more than the mighty dollar.
Clear skies,
Tom
