Jay Messeroff
Lunar & Solar Transits
What size 2" eyepiece should I get first?
Started by Michigan Dave, 09/30/2004 10:54AM
Posted 09/30/2004 10:54AM Opening Post
I have a Nexstar 8 and am getting a 2" diagonal. What 2" eyepiece should I buy first, that I will use the most? Thanks for your help.
Posted 09/30/2004 01:01PM #1
I am very pleased with my 30mm WideScan II on a C-8 as well. I have also used a friends UO MK70 40mm and it was nice as well, BUT gave no better views or fov than the 30mm.
Walt
Posted 09/30/2004 11:09PM #2
Nagler 20 Type5
Posted 10/01/2004 12:14AM #3
Hey David,
I've got a Meade 8" (LX-90), so our scopes are similar. (It's my first.)I think you want to start WIDE and then work back to higher power.
I couldn't see forking out the bucks for the 35 or 41mm Panoptics, so I opted instead for a Meade 40mm Superwide. It will provide BIG views of the larger open clusters, nebula, and the Milky Way starfields.
Next, I added a 27mm Panoptic. It's definitely a sharper ep. Still a wide fov, but with a bit more power . It brings in sharp images of many nebulas, open clusters, and galaxies. M81 & M82 fit nicely in the fov.
I'm thinking about a 20mm Nagler T5 next. 20mm is the theoretical sweet spot for our scopes. (Focal length divided by f/#).
By the way, if you haven't already purchased your 2" diagonal, I'd recommend the William Optics unit.
It's a great value.
Have fun shopping!
Linton
