Where can I get bulk foam, pluckable or not.
Started by jseivert, 09/08/2009 10:51PM
Posted 09/08/2009 10:51PM Opening Post
I'm looking to redo some of the foam in my cases but I can't find anything like the eggcrate or pluckable foam. I need to do 2 ep cases, ~24"x12"x6 & 12x8x5. A 6" refractor box, Atlas box, and an accesories box ~24x14x8 for finder, focuser, etc.
No luck at Hobby Lobby. Any ideas?
Posted 09/08/2009 11:27PM #1
I think I used this place or something like it:
http://www.thefoamfactory.com/
John
Posted 09/09/2009 12:22AM #2
Same as John says. Easy to cut and holds its shape well. Talking about the 2.2# 2" black polyethylene foam.
Jud
I Yam What I Yam!
Posted 09/09/2009 12:48PM | Edited 09/09/2009 12:52PM #3
You might look to see if there is a local source in your area. There are a couple of local companies in Oklahoma City that make and sell several kinds of foam that I buy and cut out myself. I especially like closed-cell foam becuase it doesn't absorb moisture from the atmosphere like open-cell foam does, and it is more rigid, which helps protect heavier items like mounts. Some of the local sources I've used are either manufacturers, packaging shops, or upholstery shops.
I used to fly professionaly and flew to and through Wisconsin several times. I may have gotten clearances from you!
Oklahoma State University--The University of Oklahoma!--GO POKES!! GO STATE!!
Posted 09/10/2009 05:45PM #4
Try www.foamrubber.com.
They are located in Boston, MA and will precut sheet in various thickness to fit your cases. I use their "ester" foam which does not out gas.
Posted 09/10/2009 08:35PM #5
Hi Jeff,
I have purchased from these folks many times.
http://www.foamonline.com/
Larry
