Wizard Nebula
Wide-field Complement to my C9.25
Started by atracht, 06/02/2005 05:48PM
Posted 06/02/2005 05:48PM | Edited 06/02/2005 05:48PM Opening Post
I'd appreciate your suggestions for a wide-field scope that would complement (and maybe piggyback on) a C9.25, primarily for visual work. I'm thinking about a Televue NP101, with a reasonable aperture and wide FOV, but I'm open to suggestions.
Allen
Posted 06/02/2005 06:29PM #1
Allen
You're thinking much wisely Allen ;-). The NP101 has a very wide and also very flat field with enough aperture to nail those huge objects that won't fit into the C9.25.
Ron the 4-inch Tall Evangelist B[ee]
Posted 06/02/2005 07:23PM #2
My only concern with the NP101 is weight on the mount. Might be fine, might be pushing the mount a bit depending on which mount you are using.
The Borg 101 is a very lightweight scope, and a bit cheaper than the TV NP101. Probably not quite as good color correction, but if the weight is an issue it might be worth considering.
Jarad
Posted 06/05/2005 12:22AM #3
"...but I'm open to suggestions."
Ok.
How 'bout a StarBlast ota? smile
Posted 06/06/2005 04:59AM #4
Hi Allen,
Re: I'd appreciate your suggestions for a wide-field scope that would complement (and maybe piggyback on) a C9.25, primarily for visual work. I'm thinking about a Televue NP101, with a reasonable aperture and wide FOV, but I'm open to suggestions.
I have a C9.25 on a CG-5 (Dual Drive) mount with Vixen Wooden legs. I also use a TV Genesis on it occasionaly. Both work fine for visual but it's a bit nore than the mount can handle for Astrophoto work.
The NP101 is a Great scope. I bought an NP-127 which I love. Only thing I'd probably replace it with is an A-P 130 StarFire. Hope that helps.
Clear Skies, Bill
Posted 06/06/2005 07:41PM #5
I appreciate all of your suggestions. In the meantime, however, I found a local FS-128 at a very reasonable price. I don't know if it complements the C9.25 or is just in a different league, but I think it will be great fun!
Just one item about it that bothers me: the straight-through finder. It's a great 7x50 finder, but it's nearly unusable more than 45 degrees above the horizon (even with my G11 tripod at full extension). Is there a reasonable right-angle replacment (even of lesser quality)?
Allen
