Mark Eby
M33 Triangulum Galaxy
13mm Ethos should i jump?
Started by chasp, 02/28/2009 05:39PM
Posted 02/28/2009 05:39PM Opening Post
I'm thinking about buying a used 13mm Ethos. I have always loved my TV Nags and TV WF's.
Some of you guys know i am a planet guy most times but do enjoy wide views of deepsky objects.
I have a Dan Joyce 8" f/6.7 Newt with what could be the best 8" Mirror i have ever owned.
I only have a 1.25" focuser so that leaves out the 2" 17mm Ethos, i also have a 11mm Nag T6 and a Meade 4000 13.8mm SWA. SO you guys think i would love the 13MM Ethos?
I could always sell my 11mm Nag and Meade 13.8mm SWA is i were to keep the 13mm Ethos.
Chas
Posted 02/28/2009 05:49PM #1
Yes.
Uncle Rod
Time on your hands?
Posted 02/28/2009 06:12PM #2
Head first and don't look back!
"In the beginner's mind there are many possibilities, but in the expert's there are few." Shunryu Suzuki[COLOR="Blue"][/COLOR]
Posted 02/28/2009 06:16PM #3
Jump? The only question is how high! grin
My only concern would be that big eyepiece hanging off a 1 1/4" focuser.
The Ethoi are actually great planetary eyepieces,
contrary to what you might expect.
Linton
Posted 02/28/2009 08:05PM #4
Hi Chas--
I also have an 8" with a great planetary mirror (f/6) and a 1.25" focuser--without doubt the best 8" I've ever looked through...I use an 11T6 and 16T5 with 2X and 3X barlows on the planets (and sometimes a 9mm), and I have a 13 ethos. Bottom line, I could not imagine parting with my 11T6.
The ethos is truly a fabulous eyepiece, but it has ergonomic issues. If you can put it in the focuser and leave it there, it's incredibly good. But if you like to swap eyepieces back an forth, it's a pain. In a barlow it sticks out of the focuser a long way, and it is pretty heavy--in a 3x barlow it's just a bit ridiculous. (I do occasionally put it in a 2x barlow, and that yields a nice power on Jupiter--around 200x in your scope, 180 in mine--but I like more power on Saturn.) Also be advised it requires quite a bit of out-travel in a 1.25" focuser. Now since on the planets I generally use a barlow (maybe you have shorter eyepieces), and I also swap out eyepieces a lot until I find a sweet spot, I find I do not pull out the ethos very often when looking at the planets. It's unwieldy to take in and out of a 1.25 focuser: it's finicky to get the set screw to line up with the indentation in the 2" skirt of the ethos, while simultaneously avoiding hitting the convex field lens with the edge of the focuser. (In a 1.25" focuser that's a real issue--not so with a 2" focuser). In other words, it requires one to develop a little technique to deal with it in a 1.25 focuser--unlike with the relatively carefree smaller eyepieces.
OTOH on deep sky nothing touches it in its magnification range--for this purpose it really does replace everything from an 11T6 to a 17T4...its sharpness and immense field of view yield a completely new experience in DSO viewing. And this allows me to just put it in the focuser and leave it there...
But don't sell your 11T6 to pay for it if you're into the planets--my two cents, as they say.
--geo.
George Golitzin
Posted 02/28/2009 09:13PM #5
The 13mm Tele Vue Ethos is easily the best and my favorite of all the eyepieces that I've owned over the years. (I sold my trusty 13mm Nagler T6 after I purchased the Ethos.)
One of my telescopes is an 8" f/6 Starsplitter Tube Dob. The 13mm Ethos works superbly with this scope, producing a bit larger than one degree true field of view at 94x. As has already been mentioned, the 13mm Ethos is rather large. That isn't a problem for me, however, since the Starsplitter has a 2" focuser.
Dave Mitsky
