Ruben Tommasi
Andromeda Galaxy (M31)
Brandon 32mm field stop question
Started by Doug Peterson, 03/09/2008 11:18PM
Posted 03/09/2008 11:18PM Opening Post
I have a Vernonscope 32mm probably from the 80s, I see no field stop. Is it missing? Or did Chester design it so the internal threads formed a quasi-field stop. I have seen this before on a couple oculars. What does yours look like?
"--Granted, that's a worse case scenario. The destruction might in fact be ... limited to our own galaxy."
Posted 03/10/2008 01:19AM #1
Hi Doug.
Call it insanity but I've had at least 3 32mm Brandons. Two of them, an aluminum-sided one from the 50s or 60s and a black one from the 60s (both flat-tops), had field stops. I had another flat-top from the 70s that apparently did not. I've never owned one of the more recent variety with the rubber eye cup so I can't comment on that design.
Hope this helps,
John
Posted 03/10/2008 11:03PM #2
Hi Doug,
I have a 32mm Brandon that I purchased in the late 1980s. This model has a black annodized barrel with engraved white lettering and the rubber eyeguard. It came with red soft endcaps. My unit has a small field stop threaded into the top of the mounting barrel.
Regards,
Blake
Posted 03/10/2008 11:12PM #3
How tall is your eyepiece, and what exactly is engraved on the barrel?
Joe Bergeron
Moderator, Astro-Physics Forum
