Jay Messeroff
Lunar & Solar Transits
Eyepiece advice for a Lunt solar scope
Started by RobertHowe, 08/01/2010 03:06PM
Posted 08/01/2010 03:06PM Opening Post
I am enjoying a new Lunt 60 mm hydrogen alpha scope, when doubled stacked (aperture 50mm, FL 500) the image is wonderfully detailed. In a 9 mm Nagler EP or an 18 mm Coronado CEMAX Barlowed 2x the sun just FILLS the field. Unfortunately both of these set ups are a little dim.
Can I have advice on finding an 8-10 mm EP with a decent field stop and a VERY bright image? It looks like the field stops will be a little tight on the TeleVue 11 and 8 mm Plossls (9, 6 mm) or I would buy these right off. All of my other EPs are TeleVue Naglers, Panoptics and Ethos.
Thanks!
Robert Howe
Wilbraham MA
TeleVue 85 f/7 // Astro-Physics Traveler 105 f/6 // Astro-Physics 130 f/8.35
Coronado 60 DS
"Scopes, Brains and Wisdom--but no Beauty"
Posted 08/02/2010 07:33PM #1
I have the exact same scope as you. I'm using 16mm, 11mm, and 7mm Naglers with it. When I observe I put a towel over my head. That overcame the dimness with the higher power EPs. I know that doesn't really answer your question but it's a cheap solution.
Andreas
DSOs observed:
NGCs 2005, ICs 103, Other 70, Palomar GCs 6, Abell PNs 12, Herschel 400: 316.
Equipment
Celestron CPC 1100, Lunt 60mm Ha Solar Scope
Posted 08/03/2010 05:36PM #2
Hi Robert.
Nice scope. I've got the same setup.
I mostly use a TeleVue 8-24mm zoom with it, mainly for the sake of convenience. I can dial in the appropriate power level to suit the seeing conditions, usually between 12mm and 16mm. Sometimes more FOV is helpful, especially when viewing, or scanning for, prominences.
Lately, I've been using my TV BinoVue, with a pair of 24mm Panoptics. Now that's a nice view! A bit unwieldy though, especially on my Telepod mount.
I think the best single EP I've tried was the 10mm, or perhaps the 13mm Ethos, but it won't fit in the carry case.
Seems like an 11mm or 13mm Nagler would be ideal, but I don't currently have either.
Regardless, the Lunt definitely has a "sweet spot", so a little extra FOV is quite helpful in keeping the image there.
Enjoy our neighborhood star! grin
Linton
Posted 08/04/2010 08:31PM #3
I have the same scope, too, and find the UO Orthos are very nice when viewing Sol. I've tried the 13 and 8 Ethos, and a 24mm Panoptic with a 2x barlow, but IMHO the view in the Orthos are better with brighter images and good contrast. I always start with the 18mm to get the whole view and to locate any prominences, bump it up to the 12.5mm, and if seeing permits I go to the 9mm.
Before getting the Lunt I was thinking about selling off the Ortho set. I'm really glad I kept them. 8)
