Eyes
Started by Brianpope, 12/06/2007 03:10AM
Posted 12/06/2007 03:10AM Opening Post
Maybe slightly off subject, however related.
My eyes have hit the old age arena hard at 45.
I can not see things up close, maybe readers are the answer. What do most of you do ? I realized this last year when my 9mm rectile lines were blurry for some reason. When at the eyepiece do you put your 3.0power readers on just to look into eyepiece? Does it only matter if you are trying photography?
Thanks, Brian
Posted 12/06/2007 04:08AM #1
For what it is worth, you may or may not ever need glasses at the EP. One night I ran several hundred people through a session on the moon and never had to refocus and only one kept their glasses on. With dimmer objects and a larger exit pupil it could be a problem. I am 66, read with 3.0 reading glasses, but can focus through the EP fine without glasses. Others have to refocus from my settings (we're talking DSOs). Go without the glasses as long as you can.
I Yam What I Yam!
Posted 12/06/2007 04:16AM #2
Welcome to the club Brian. I was about 45 when I needed glasses. Over a few years, it went from pretty good eyesight, to where my wife held the menu across the table for me to see. I went in to the eye Doctor and got glasses. I put them on the first day and have warn them every day since. Fortunately, I don't need them to view with a telescope. But it is a pain to do the on again off again to view then look at a chart. 8)
Buck
Posted 12/06/2007 05:06PM #3
Brian,
The inability to focus close as you get old, does not change the optical precision of your eye. i.e., if you have 20/20 vision, then when you can't focus close you still have 20/20 vision. The inability to focus close with age is due to the "drying out" of the lens and it then becomes less pliable so your eye muscles can no longer bend it enough for close focus.
In any event, as long as you don't also have astigmatism and such, this should have no impact at the eyepiece. It has zero impact for me...all it means is I always have a pair of the cheapie dollar store +1.75 diopter reading glasses in my pocket for when I need to read a chart or such.
