Focuser size
Started by scottw, 03/13/2009 06:39PM
Posted 03/13/2009 06:39PM Opening Post
Hello,
I have a newish Orion reflector andthe focuser tube is around 1.638" inside diameter. What is this for?
Scott
Posted 03/14/2009 04:12AM | Edited 03/14/2009 04:13AM #1
The drawtube diameter quite often is larger than the eyepiece to avoid vignetting and/or to allow proper baffling. You will use an adaper or eyepiece holder to step this down and hold the diagonal or eyepiece.
Vixen uses 41mm ID/43 mm OD with M43x0.5 male thread for 1.25" and 58mm ID / 60mm OD with M58x0.5 female tread drawtubes for 2" eyepieces. Many focuser to day still use these sizes.
Michael
