LBN 576 - The Garlic Nebula
Concrete info for....Ivan
Started by ttolla, 09/12/2005 11:18AM
Posted 09/12/2005 11:18AM | Edited 09/12/2005 11:19AM Opening Post
Hi Ivan,
I see you have plenty of input on this subject already but....
Concrete reaches its maximum strength in 28 days. It should be "damp cured" for at least 7 days before you apply any torque to anchor bolts. Damp cured by Klaus' method is what is accepted in the construction field. This is regardless of what PSI rating the concrete is that you have mixed.
The most important item is the amount of water added when mixing. Concrete mixes are rated in PSI based on the assumption that the person mixing is going to add the instructed amount of water. Too much water will decrease the PSI rating and cause excessive shrinkage sad (not good)
I know this is a little late, but the best pre-mixed concrete you can buy is "5000 psi Hi-Early Strength".
Sorry about the late post. Maybe someone has posted this info already.
Tom T.
Guilford, CT smile
Posted 09/12/2005 12:38PM | Edited 09/12/2005 12:40PM #1
Well Tom, just a lil' late, but thanks anyways, as this good information might help somebody that might be thinking about making their concrete pier...
To be honest, I had NO CLUE on the PSI ratings or the "shrinkage" of concrete either (I used the QUICKRETE 4000PSI mix), but I really-really-really hope it all came ok... if not, then I have a very heavy NO-GOOD concrete block to get rid of...
We will see how it all goes... I'll keep you all posted.
Thanks my friends, and clear skies to all! 8)
