Horsehead Nebula
Re: Any decent mounts for around 1000 dollars
Started by atomant, 11/23/2011 05:02PM
Posted 11/23/2011 05:02PM Opening Post
Hi Gary,
The 6in Mak is a high powered scope requiring a nice solid mount to prevent the "dancing stars".
If you must have goto option, Meade's new LX80 and Celestron's tried and true CG5-Goto will fit your budget and weight constraint.
Much less massive than the CI700.
Personally, I like starhopping and the ability of manually fine adjusting my RA-DEC motions. I am using the Orion SVP. Similar to CG5 class. With a handy star chart, it forces me to know the layout of the sky.
If your budget allows, the Orion Sirius, baby version of Atlas, is a more refined GEM.
The Voyager and Porta alt-az mounts are decent grab-n-go.
But will quickly get frustrating nudging both axes to manually track high powered views.
Best would be to test drive a few mounts if you are close to a store or check out star party.
Posted 11/23/2011 05:12PM #1
william chiu said:
Hi Gary,
I've owned a CG5 for a few years and I can't see how you can go wrong with it. For just over $600, it is a steal.
