12" Lightbridge & Pararcorr
Started by scottw, 03/07/2008 03:45PM
Posted 03/07/2008 03:45PM Opening Post
Hey,
Would there be a big diffrence using a Pararcoor on a 12" LightBridge, visual use only?
Thanks as always,
Scott
Posted 03/07/2008 05:28PM #1
Scott Anderson said:
Hey,
Thanks as always,
Scott
Look through someones' scope of close or equal focal ratio, with and without their Paracorr. The difference is there to be seen. Then decide.
Posted 03/11/2008 10:04AM #2
Hey,
Thanks as always,
Scott
A Paracorr increases the effective focal length of the scope by about 15% so it increases the magnification by about 15% and reduces the TFoV by about 15%.
If you have some fancy eyepieces (Naglers etc.) then the edge sharpness will be near perfect because the coma has been greatly reduced. A real treat.
If you have more normal eyepieces, then the edge correction will be improved as well. However with more basic eyepieces, those off-axis aberrations one sees are mostly from the eyepiece (astigmatism etc) and not coma. Adding the Paracorr will help by increasing the focal ratio from F/5 to F/5.75 thus making it easier on the eyepiece, plus it does reduces the coma.
Personally I use the Paracorr almost all the time with my F/5 scopes but I am not sure I would buy one for it, I bought it for an F/4.06 and it really pays for itself in that scope.
So, as was suggested earlier, try one out and see what you think. Sooner or later everyone is going to have an F/4.5 or faster so might as well enjoy the benefits with your current scope too.
