RICHARD COFER
VdB 141 Ghost Nebula
Celestron/Vixen C6 Focus problems
Started by [email protected], 08/27/2008 04:28PM
Posted 08/27/2008 04:28PM Opening Post
Hello everyone. I have a Celestron/Vixen C6 f/5 with a sliding focuser. My problem is that the focuser does not have enough travel to bring some of my eyepieces into focus. The 9mm ortho, 12mm widefield, and 32mm plossl will not come into focus. My 26mm, 22mm, 20mm & 15mm plossls all focus fine. Can anyone help explain why this is so. wink
Posted 09/01/2008 02:59AM | Edited 09/01/2008 03:00AM #1
Different makes and models will literally have the component elements grouped in different places within an ep barrel.
Determine which ep requires the most infocus. Then if possible adjust the primary up the tube, a bit closer to the focuser so it will focus. Sometimes it's just a matter of moving the mirror up hill with the collimation bolts.
Outfocus can be worked with para-focalizing rings, on those ep's that need to be out the focuser a bit. Or with an extension tube, which sometimes can be made with the right size piece of 1-1/4 drain pipe.
