Scott Anderson said:
Does either one, an F5 or F4.5 require coma correction for general visual observations? I htink I read where the F4.5 might require it.
Thanks for the input.
Scott
Scott:
In some sense, coma correction is a personal choice and it also depends on whether you are using eyepieces that are corrected for off-axis astigmatism at these fast focal ratios. If your eyepieces are otherwise sharp to the edge at F/4.5 or F/5, then a Paracorr can take the views to the next level, clean stars right up to the edge....
I have a small collection of Newtonians F/4-F/5 ranging in aperture from 130mm to over 600mm. I just about always use a Paracorr with a set of Naglers. Adding the Paracorr makes a noticeable improvement.
At the low powers, you can see the coma as the tails on off-axis stars, they are ignorable if the stars aren't bright, the Paracorr cleans this right up...
At high powers, without the Paracorr, those comatic tails are visible but one also has to be concerned with the effect of the coma on planetary views, the sweet spot is very small.
The diffraction limited region of a fast parabolic mirror is surprisingly small... 2.75mm at F/5, 2.0mm at F/4.5. In a 15 inch scope, these corresponds to a true field of view of 5 arcminutes at F/5, 4 arcminutes at F/4.5.
At 200X, these are apparent fields of view, the size of the "sweet spot", of about 16 degrees at F/5, 13 degrees at F/4.5. A Paracorr increases these by a factor of 6x...
So, in a sense, coma correction is an individual choice but if one wants to get the best possible views, correcting the coma is essential. Newtonians can provide quite wonderful "refractor-like" views with the combination of the good eyepieces and a Paracorr.
