[COLOR="Purple"]Here's my project du semaine! Like I need another project!!
It's an '80s vintage Meade 60mm finder. I picked it for a song (Thanks Mark!) as a rehab project.
It's obviuosly well used but seems to have decent optics with the original .965 EP. The focuser is helical and fairly smooth. There are a lot of screw marks from the rings it was mounted in. Other than those, the OTA is in pretty good shape. Every part of this thing is metal as far as I can tell. No plastic here!!
The diagonal is is pretty bad shape with a crack and corrosion/rust on the back screws. It will probably have to be abandoned in favor of a hybrid .965 to 1.25" diagonal. Then I can use whatever 1.25" EP works best...I'm betting the 19mm Panoptic will be a winner!
So far I haven't been able to remove the dew shield from the objective cell. I'm assuming it's a screw on but maybe it's a press fit? I had another refractor that acted the same way and I had just about given up on it when suddenly the dew shield unscrewed easily. I'll try some gentle persuasion with strap wrenches to see what happens.
Long term I want to clean everything up and do a nice paint job on it. I've been wanting to try a refractor paint job and this baby just screams out for new paint. Some Bondo...some sanding...cool paint...and this thing will be pretty cool!
More as I progress....
Bill[/COLOR]
Bill[/COLOR]
