Hi everyone!
I salvaged an objective from an ancient projector and after disassembling it I found three lenses: plano-convex, biconcave and asymmetrical biconvex. Their diameter is 3.5" (90mm) and focal length of the array f=16" (400mm). I put them back together and tried to look with the objective at the Moon, aligning it with different eyepieces. Magnification seemed to be right for f=400, but naturally I wasn't able to perfectly focus the image.
First I thought to build a refractor, but there are few problems. I know nothing about quality of the lenses and have no idea how to measure it. Moreover the lenses aren't multi-coated.
The second thought is to build a small, planetary reflector. I would use plano-convex lens as a blank, supporting convex side somehow. The biconvex lens could be a tool, since one side is almost flat. It could be a nice, piggyback addition to my 8"f/6...
Is it worth it? How fast can I go with 3.5" for Moon and planets observing? Any ideas how to support convex lens, so it would stay in place during grinding?
Or, should I try to build a refractor? I am not into imaging, just observations, would it suffice?
Thanks
Thanks
8" f/5.9 truss tube newtonian, made from scratch 8)
