Wizard Nebula
White glue on Velcro.
Started by chris brown, 04/25/2008 04:47AM
Posted 04/25/2008 04:47AM | Edited 04/25/2008 04:48AM Opening Post
I found this works very well...
I have a refractor, which needed a red-dot finder, and there was no way to bolt the finder to the OTA...
Double-sided tape had excessive play, and the adhesive was marginal...
I found some velcro at the hardware store, male and female strips in a roll, with excellent adhesive!
I mounted the finder to the OTA, and there was still excessive play at the Velcro contact area, so I seperated the Velcro halfs, and put some Elmers white glue onto the velcro contact area.
After drying overnight, I found that the Velcro bond was very solid!
No give at all!
My red-dot holds alignment perfectly, and won't budge when I turn on the illuminator!
I doubt that it will be easy to seperate the Velcro halfs now, but it is a very strong bond, and BTW, the Red dot finder I attached to my Vixen OTA was in fact a Vixen all metal red-dot finder!
I now intend to mount one of my plastic red-dot finders (which is half the weight of the Vixen finder!) to my 7x50 binos!
Advantages:
Super strong bond
Better adhesive than double sided tape
Twice as thick as double sided tape
Dis-advantages
Will no longer come apart!
I hope this helps someone...
Chris Brown
There's something on the Moon! 8O
Posted 04/26/2008 07:29AM #1
Thanks for the tip Chris. I don't know when, or if I'll ever have a use for your "combo", but it's a good thing to put into my "Bag-O'-Tricks", as you just never know.
Rich
