last night with an Intelliscope
Started by RUSTY845, 02/05/2006 03:08AM
Posted 02/05/2006 03:08AM Opening Post
Last night under not great sky's I pulled out the XT10i but this time i thought I would give the IntelliScope computer a work out.
I took out the leveling base I made got that set just right, then I put the scope on it and tweaked it just so. Hooked the fan up and went out for dinner. We got back home about 9:45 and you guest it CLOUDS. So I went in the house and put on the Sci-Fi channel until 11:00. The clouds were gone, I did a two star alinement with a 10mm Plossl using Betelgeuse & Polaris and got a warp factor of 0.1 ( WOW ) and and off I went. first i hit the tour button and started moving the scope.
The First object was M35 a nice open cluster in Orion and it was right in the field of the 15mm super Plossl, next was M47 another open cluster this one in Cassiopeiathen and there it was again right in the EP. Next to try something a little harder I was off to Castor a double in Gemini no problem splitting it with the 15mm. I hit the up key on the intelliscope and we were off to M81 and again I did not have to do any hunting it was right in the EP. As the night went on the list included M51, M3, NGC-2158, M35, NGC-2266, M48, NGC-2683, all were right in the field of the EP. I did try NGC-2255, NGC-2420, NGC-3166 NGC-3359 but all were + 11 mag..
This was the first time I took the time to set the scope up the right way, and you know the thing works! I wonder for $129.00 can this be adapted to other Dob's
All in all I had a BLAST.
Bob
R.A.C. Advisory Committee
NEAIC Co-Chairman
NEAF Advisory Committee
Warwick, New York
41.15984 -74.2541
[B]Takahashi MT 160
10" F4.5 Newt 8O
R200SS grin
Some kind of 127mm APO
Orion Atlas EQ-G
Losmandy G11 with Gemini
iOptron Mimi Tower
iOptrom Cube Pro
Meade DSI PRO II 8O
SBIG ST-10ME
Image Source 21AU04.AS
Posted 02/05/2006 04:10AM #1
Hi Bob,
As I reported on te XTi 10" the locator works very well and the optics are quite good.
Wonderful to hear another report that agrees with mine. smile
Posted 02/05/2006 04:18AM #2
Good job Bob, sounds like you had a good night after you got done watching Battlestar Gallactica. At about the same time locally for me, 11:00 the wind was starting to pick up towards 40 mph. We already had clouds, of course thats been pretty much the case for the last 2 months, so my XTi 12" has just been gathering dust.
Real men play Golf
Posted 02/06/2006 03:41AM | Edited 02/06/2006 03:45AM #3
Ok to put this to rest @ 11:00 pm New York time I'm going to go out in the cold air ( LOL ) and set the scope up with the base out of level 10 or so deg. i'll do the same two star alinement with a 10mm Plossl using Betelgeuse & Polaris and pick lets say m35 and see if its in the feild of the same 15mm EP i used the other night..
Bob
NEAIC Co-Chairman
Warwick, New York
41.15984 -74.2541
[B]Takahashi MT 160
10" F4.5 Newt 8O
R200SS grin
Orion Atlas EQ-G
iOptron Mimi Tower
iOptrom Cube Pro
Meade DSI PRO II 8O
SBIG ST-10ME
