The boy scouts had a camp in at the church friday night. The Webelos 2 were invited also. So being the leader of the Webelos 2 i went and helped but i had to work the next day. I took my 8" celestron reflector on lxd75 meade goto mount and set it up in the parking lot. Under the bright lights i was unable to get a polar alingment so i couldnt use the go to. We looked at the moon, The comet 17p/holmes, and the seven sisters. Even some of the church goers came and looked as they were leaving there get to gethers. I really had a great time and i think every body was impressed by what they saw.
Parking lot astronomy
Started by slotdrag, 11/22/2007 12:17AM
Posted 11/22/2007 12:17AM
Opening Post
Posted 11/23/2007 11:18PM
#2
Rick;
I've had that problem also where you can't see the pole star thru the finder either because of the light pollution or because it's blocked by an object like a tree etc. There is a way around that, if you can see a few stars near the ecliptic, due south and due West(or East),...try to do a polar alignment using the drift method. It uses the main mirror so it's increased light gathering ability should make it easy to find suitable stars. It takes quite a bit longer but it's an invaluable tool in these circumstances. I also find it kinda fun to do and relaxing as long as you don't have other pending astro things to do with the scope. When you get good at it,it should take about 30-45 min to get it spot on. Gerry
Funding Member
