Iris Nebula
What kind of tripod?
Started by pug_dog, 08/12/2007 09:03PM
Posted 08/12/2007 09:03PM Opening Post
I have developed an interest in the short tube refractors. I am having a problem finding a decent photo-type tripod that works well for the task of "grabbing the whole setup and take it to the yard".
I have tried a variety of the camera store, garden-variety of tripods (sub $150 range) but my problem is tracking...when I get an object in the field of view, the controls don't tighten smoothly, causing the scope to move off target when I let go of the control.
I have looked at other expensive (again photography, alt-az type) tripods but just wonder if there is a good standard model, or feature set, to look for, that I should be looking for? Any ideas?
TIA...
--Ken
Posted 08/12/2007 11:06PM #1
Hey Ken,
I'm using the Paragon mount, too, and I find it fulfills the purpose for which I bought it. With an ST-80 costing less than $200, I didn't want to spend a fortune on the mount. For me, the Paragon is a small, lightweight, inexpensive package. I've been using Orion's slow motion adapter, which was okay under 100X, but recently upgraded to a Bogen 410 fully geared head. Works for me, whether it would work for you depends on what you want to do, and how much you want to spend.
Larry
Posted 08/13/2007 05:37AM #2
I've a pipe mount I use for a short nine pound newt and a home made 80mm. I have no pictures of my own to post, but here are some examples of what other's of our peer's have done in this area.
http://www.astromart.com/forums/viewpost.asp?forum_post_id=538663&poll_id=&news_id=&page=
TIA...
--Ken
Posted 08/16/2007 01:54PM #3
Hi Ken,
I made a modification to the set-up I'm using last night. I had an ST-80 on a Paragon tripod with Orion's slow motion adapter for fine tuning (inexpensive, lightweight grab'n'go, relatively stable), last night I swapped out the Orion slo-mo for a Bogen 410 fully geared head. What a difference! Yes, it adds a little weight to the set-up, but it's still one hand grab'n'go. What IS significant, however, is the stability of the whole rig. Where the Orion unit would begin to shake pretty seriously as you approached 100X, with the image dancing around getting harder to focus, now the image stays rock stable as you change focus. The geared head does not reach end of travel and need to be re-set as the Orion did. You can just keep turning the head, enjoying steady views without shakes. This system is a keeper for me!
Larry
