Oddity in M41
Started by farmerdavid, 02/02/2006 12:20AM
Posted 02/02/2006 12:20AM Opening Post
Two nights ago I went out to my dark site and was treated to a night of very good transparancy. I spent most of the night viewing Galaxies. Late into the night I viewed M41 when it was high in the sky. I was shocked to see what appeared to be a dim planetary nebula within the cluster. I thought "Wow!", have I never seen this because I've never looked at M41 from a dark sight? I figured I'd look it up and read about it later. Well, after a bit of research, there doesn't appear to be a planetary in M41. Unfortunatly I didn't record the position or spend the time to really examine it since I was on a galaxy quest.
Can anyone help me on this? Please don't laugh. I'm not a very experienced astonomer.
David
Posted 02/02/2006 01:08AM #1
Hi David,
There's no planetary nebula in M41, at least one that is easily observerable. I posted a pic of M41 on the DSLR photography forum a couple of days ago, you can see there's none in the cluster. Perhaps you might have stumbled on M46, which is very close by M41 and bright. Now that has a planetary nebula in it that you can easily pick up especially with a 4" scope and bigger.
Ivan
Posted 02/02/2006 01:13AM #2
Yup, that was M46 alright!
Posted 02/02/2006 01:15AM | Edited 02/02/2006 01:17AM #3
Indeed, M46 is the only one with a Planetary Nebula built-in... wink
Posted 02/02/2006 02:05PM #4
Thanks all . I'm sure it was M46. That's what happens when you rely on goto, and don't bother looking up. I learned a lesson.
David
