TV-102 Hot Brew: Nova Sgr 2002
Started by ronbee, 09/22/2002 04:15AM
Posted 09/22/2002 04:15AM Opening Post
Having been under supernova of work lately (had to work today) :-(, my TV-102 Light Cup beckoned me to go nip this new nova, reportedly around magnitude 5. I could see the skyglow in the east due to the rising moon (though the moon itself wasn't seen). There was no time for scope cooldown (it was a hot day today), no time for dark adaptation :-(. We observed from 7:50-8:20pm PDT.
Easily found at 22x (40mm Pentax XL) and most definitely not one my printed chart 'cause it's quite bright. It forms almost a perfect triangle with the mag 6.14 star SAO 187519 and mag 6.25 SAO 187584. The Nova Sgr 2002 seems brighter than these two stars. Having a 3d FOV, it was easy to find that the mag 5.91 star SAO 187468 seems to
have the same magnitude as the Nova while the mag 5.0 Nu2 Sagittarii is clearly brighter than the nova. Through the 12mm Radian (73x), the Nova there's a "T" shape asterism south of the Nova (mag 9.2 SAO 187580 which is a double star, GSC 6294-1465, SAO 187591, SAO 187585 and GSC 6294-1334). The Nova is much brighter than all of these stars. Double checking the magnitude of the Nova against the mag 5.91 star SAO 187468 seems to confirm equality. Color is white. Immediately, we wonder if there are nova with yellow, red or blue colors. At 176x (5mm Radian), the Nova itself forms a "T" shape asterism with 2 very dim stars GSC 6294:1085 and GSC 6294-1104 and the double SAO 187580. Neat, the Nova nows looks like a nice round, very small dot. At 220x (4mm Radian), the very, very dim star GSC
6294-2448 to the west of the Nova is seen with averted vision. There are also stars scattered around the region with averted vision.
Someone said that a nova occurs in a binary star system. We looked really hard and couldn't see any. Perhaps, it's closer than 1 arcsec or dimmer than the 4" Light Cup could see :-(.
A nice hot break from work with the quick cooling, quick deploying TV-102 Light Cup refractor ;-).
Ron B[ee]
Posted 09/22/2002 02:53PM #1
Ron,
Do you have the RA and DEC coordinates for this object? I'd like to give it a try.
Debbie
Posted 09/22/2002 10:06PM #2
Ron
You have raised an interesting question as to the colour of the nova. The web site you provided (thank you) has a spectrum which shows, amongst other things, a very strong Halpha line at 656 nm ... so perhaps the nova ought to appear pink? The question of star colours is given a fine treatment in David Malin's book "A View of the Universe". (Perhaps also in his "Colours of the Stars"). With RA drive on take a photo in focus. Then move a small distance in declination, defocus slightly and double expose. Repeat several times. This gives a series of NON-concentric circles of increasing size, of which at least one will give the "colour" of the star, at least as recorded by the characteristics of the film. I don't have a suitable setup to do this but it would be interesting if someone could take such a photo and report the colour of the nova on Astromart.
Anthony Allsobrook @ 41*S 175*E
Posted 09/23/2002 02:54PM #3
Ron,
According to theory classical novae result from some kind of mass exchange in close binary systems. You will, however, never be able to recognise them as doubles visually. As such they are out of range even for the most powerful scopes. A very high number of binary stars belong to the class "spectroscopic binaries". Due to the orbital motion in the system, the the spectral lines make periodic shifts in their position, in some cases where both stars are equally bright the spectral lines sometimes appear single, sometimes double. Therefore the spectroscope enables very presice determination of their orbital period. All three components of Castor are such spectroscopic doubles. In most cases, however, even spectroscopic doubles have too large separation for mass exchange to occur, and for potential novae both the separation and the orbital period is very low, perhaps a few hours or days.
So, missing the duplicity of Nova Sgr 2002 is no indication of poor optics of your Light Cup.
