The seeing was so rock steady last night (would have been perfect if transparency was 100%). My TV-102 Light Cup and I went out to catch "near collision" of Io and Ganymede. At 9:20pm (5:20am UT) blocked by thin clouds, they looked like a cleanly split close double stars at 146x (6mm Radian) through the clouds - neat! Noteably, both moons
looks like equal size disc. Jupiter itself was rock steady but very low contrast through the clouds :-(.
I noticed that Saturn wasn't covered by clouds and indeed the view was very steady and sharp enough at 293x (3mm Radian). Then I noticed the shading on the B-ring at both ansae, something I've never seen before. Going down to 176x (5mm Radian and Tak LE) and 220x (4mm Radian) resulted in higher contrast. I quickly ran into the house, grabbed my drawing pencils and blank paper and here's the sketch I
made at 176x and 220x. (Boy, I need to print out a few copies of the planet's templates so they're ready to go :-().
http://members.cox.net/ronby/Planet-Sketches/Saturn-B-shade.jpg
Checking with Eric Jamison's guide, the feature is called Shading on the B Ring.
http://home.fiam.net/ericj/saturn_color.html
I usually dismissed cloudy skies but tonight I learned rock steady seeing could be had during moments when the clouds parted ;-).
One question for sketchers. Although the full moon was nice for sketching, I found that I couldn't tell the difference between my various pencils :-(; they're all the same colors (dark green)! I had to use my red light to read the number - very annoying and distracting to say the least. How do you guys solve this problem? BTW, I now
see the difference between the regular eraser and artist eraser (you know the one that feels like clay ;-).
Ron B[ee]
Ron B[ee]
