Europa Transit Tonight (8/7)
Started by AlanFrench, 08/07/2007 01:59PM
Posted 08/07/2007 01:59PM Opening Post
9:49 PM EDT II TrII - Europa moves in front of Jupiter (from the east).
Seeing a satellite itself in front of Jupiter can be difficult. It depends a great deal on the coloration of the moon and the coloration of the region of Jupiter it passes in front of, and on the seeing.
The easiest way to see one of the moons in front of Jupiter is to watch it as it begins the transit, and see how far across the planet's face you can follow it. For east coast, this transit of Europa provides a fine chance to do this.
For folks farther west, here are the times for the shadow ingress, transit egress, and shadow egress.
4:11 UT II ShI
4:24 UT II TrE
6:46 UT II ShE
Clear skies, Alan
Posted 08/08/2007 12:02AM #1
Thanks for the heads up, Alan.
I'll try to catch it.
Linton
Posted 08/08/2007 06:17AM #2
I saw Europa move across jup's globe cool stuff, it was vry bright lke a star on jups face it faded as it moved across jup but could still see it with averted vision,it was white moon against a white zone so it was hard to follow.
Posted 08/08/2007 01:33PM #3
Alan: I didn't catch the transit of the moon itself but I got a nice view of the shadow transit and some wonderful views of Jupiter itself. I did see some interesting structures in one of the cloud band, three (I think) lines at maybe 70 degrees from the horizonal, looked like little tick marks.
The seeing was quite good and the night clear. Good views all around. It was one of those evenings that reminds me I love looking at the night sky so much. The past month has mostly been sneaking through sucker holes with a small refractor looking at a few doubles and bright clusters.
Last night, because of the transit, I took a gamble as set up my 12.5 inch F/4.06 Discovery DOB. It was clear an hour before sunset but there has been a pattern of clouds that roll in off the ocean right at sunset and last night I was rewarded. Good seeing (still couldn't split gamma corona borealis at 0.7), great clarity. I split Antares at 100x...
It is time though for a 2 speed focuser on that scope. At F/4.06 the depth of focus is shallow and last night that was quite apparent viewing Jupiter. The scope is steady enough and the seeing good enough that I could see the detail flash for just a moment as I passed through focus. With care I could focus but this really made it clear the importance of having a fine focus option on such a fast scope.
Another note, having a variable speed fan has helped this scope quite a bit. I use a single big fan and it probably causes some vibration (certainly causes noise) at full speed. I started running it off a generic 110 to 12-9-7.5-5-3 volt converter and that helps too.
It was a glorious night.
Posted 08/08/2007 01:52PM #4
Hi Alan,
I caught it, I was doing great with my 8" Dob, binoviewers, and 170x. I used my new Baader MSG for the first time on my Dob. I had followed Europa many times with my smaller refractors, but this would be the first time with my Dob. grin
Alas, it was not to be. cwy I was doing good at first, I could see Mr E well into the "white zone" of the disc, but as Jupiter moved lower into the sky, things suddenly went wild up there and I lost total sight of it. Oh well! I still had a great time!
WHY does every car in the neighborhood decide to drive by with their high beams on at the exact time of ingress??? :S
David E
