I made an observation of Jupiter on February 10, 2005 at 06:30 U.T. using my 9-inch F/13.5 Maksutov-Cassegrain under good seeing conditions (6-7/10). The planet exhibited much detail, especially the North Equatorial Belt (NEB) and the South Temperate Zone (STZ). I welcome any comments that you may have on my observation.
Date (U.T.): February 10, 2005
Time (U.T.): 06:30
L1141.1, L2 274.1, L3 292.2
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 248x
Filters: None (IL)
Seeing (1-10): 6-7, Antoniadi (I-V): III-II
Transparency (1-6): 4-5
Notes:
South Polar Region (SPR): Appears dark to dusky (3-4/10) and mottled.
South South Temperate Zone (SSTZ): Appears thin, irregular and bright (7/10).
South South Temperate Belt (SSTB): Appears dusky (4/10) and irregular ("sections").
South Temperate Zone (STZ): Appears bright (7/10) and irregular ("chaotic") with several small, bright (7/10) ovals noted within it.
South Temperate Belt (STB): Appears dark to dusky (3-4/10) and irregular following the CM.
South Tropical Zone (STrZ): Appears bright (7/10) but no detail visible within it.
South Equatorial Belt (SEB): Appears dark to dusky (3-4/10) with irregular northern and southern borders (condensations) and a thin, bright (7/10) undulating band over it's midsection.
Equatorial Zone (EZ): Appears bright (7/10) with dusky to dull (4-5/10), elongated condensations within it.
North Equatorial Belt (NEB): Appears dark to dusky (3-4/10) with thin, bright (7/10) rifts over it's midsection. Dark (3/10) condensations (or barges) are noted over it's northern border (NEB-N). Dark festoons are noted over the southern border (NEB-S).
North Tropical Zone (NTrZ): Appears bright (7/10) but no detail is visible within it.
North Temperate Belt (NTB): Appears dark to dusky (3-4/10) with an irregular ("fuzzy") southern border.
North Temperate Zone (NTZ): Appears bright (7/10) and irregular in width.
North Polar Region (NPR): Appears dark to dusky (3-4/10) and mottled.
The best of luck in your own observations and imaging of Jupiter.
Regards,
Carlos E. Hernandez
Time (U.T.): 06:30
Magnification: 248x
Filters: None (IL)
Notes:
Regards,
Carlos E. Hernandez
