Hi Richard,
Really good seeing conditions as the evening, April 16.2004, progressed.
Of note was the very marbled appearance of the NEB.
Festoons were well defined with the one just preceding the CM being dark.
The sloping dark rift in the SEB also well define. Just south of the rift SEB appeared somewhat brightened.
The southern NPR had a large brightening in the following half that was quite a bit wider than the NNTez is usually. Its somewhat overemphasized in my sketch so you can see it better.
The STB sloped southward on the following side. The northern edge of the SPR was much darker than usual.
I think System 1 @ 43 and System 2 @ 298. That's a rough estimate.
Best, Sol Robbins
Best, Sol Robbins
