Hi,
Finally got my first sketched observation regarding Jupiter with good seeing. My Apogee H.D. EQ head, same as the Meade LXD55, worked well as my CG5 mount took a spill and became unuseable.
There is a lot of activity in the STB with what I believe is the BA oval about halfway between the following limb and the CM, as well as a couple of others. On balance, the SPR appears a little lighter than I remember.
The SEB appeared mottled and a dark rift was prominent.
The NEB also has a segmented but prominent dark rift that's punctuated with some light spots. Festoons were fuzzy with the most prominent one just following the CM.
Sol Robbins
Sol Robbins
