Mars Observation (July 18, 2005)
Started by Martian, 07/21/2005 06:38AM
Posted 07/21/2005 06:38AM | Edited 07/21/2005 06:41AM Opening Post
I made an observation of Mars on July 18, 2005 (06:50 and 07:15 U.T.) using my 9-inch (23-cm) F/13.5 Maksutov-Cassegrain under average (5-6/10) seeing conditions. The planet presented an impressive amount of detail although only subtending 10.4 arc-seconds. Most notable was the presence of significant cloud (haze) activity over the Electris/Eridania/Ausonia region, especially under blue (Wratten 38) light. I do not believe that dust activity was present over these regions, but instead typical atmospheric phenomena (clouds and haze). I welcome any comments on my observation.
Date (U.T.): July 18, 2005
Time (U.T.): 06:50 (left image) and 07:15 (right image)
CM: 211.9 (left image) and 218.0 (right image)
Ls 252.0, De -20.0, p 0.84, 10.4"
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 248x and 388x
Filters: Wratten 30 (magenta) and 38 (blue)
Seeing (1-10): 5-6, Antoniadi (I-V): III
Transparency (1-6): 3 (haze present)
Notes:
Left image: An observation of Mars made at 06:50 U.T. under integrated light (IL) and also using a magenta (Wratten 30) filter. The South Polar Cap (SPC) appears brilliant (10/10) surrounded by a dark (3/10) collar comprised of Mare Australe, Thyle I and II, and Mare Chronium. A very dark (2.5/10) albedo feature was noted at the approximate location of Ulyxis Fretum (190*W, -63*). The regions of Electris, Eridania, and Ausonia appeared to be partially obscured by a bright (7/10) haze (water-ice clouds/ low-lying fog?). Mare Cimmerium appeared dark to dusky (3-4/10) with it's southern border partially obscured by the bright (7/10) haze. Mare Tyrrhenum and Syrtis Minor also appeared dark to dusky (3-4/10) following the CM. Elysium was visible over the north-preceding (Np) limb and appeared to be obscured by a bright (7/10) haze. Cerberus/Pambotis Lacus/Eunostos I (4-5/10) were visible along Elysium's southern border. Zephyria, Aeolis, Aethiopis, and Aetheria appeared bright (7/10) without any detail visible within. An extremely bright (9/10) evening limb haze (ELH), North Polar haze (NPH), and morning limb haze (MLH) was noted as well.
Right image: An observation of Mars made at 07:15 U.T. using a Wratten 38 (blue) filter. A wedge-shaped bright (7/10) was noted to extend between Electris, Eridania, and Ausonia (water-ice clouds/surface fog?). A bright cloud (7/10) was noted over Elysium. The evening limb haze (ELH), North Polar haze (NPH), and morning limb haze (MLH) appeared extremely bright (9/10). The South Polar Cap (SPC) region appeared extremely bright (9/10) as well.
The best of luck in your own imaging and observations of the red planet.
Regards,
Carlos E. Hernandez
P.S. I apologize for being absent from this excellent forum for some time. My medical duties have prevented me from even looking up.
Martian's attachment for post 25630
Posted 07/21/2005 06:59AM #1
Your MK91 is a scope I've been admiring from afar for a while, so your fine sketches have always been a treat.
Any comments on how it compares to other scopes you've peered through at the planets (C8 etc.)?
Any cooldown issues?
Posted 07/21/2005 11:35AM #2
Carlos
Nice to have you back! Another very fine drawing!
Thanks
Bill
Posted 07/21/2005 06:46PM #3
Great sketch Carlos, it looks likewe are in for a real treat with this Mars opposition season as long as a big dust storm doesn't happen.Glad to see your back sketching.It will be great to see how Mars has changed since the last opposition.
Posted 07/25/2005 12:00PM #4
Bill, Thomas, and Tim
Thank you for your compliments on my observation of Mars. I was impressed with the amount of detail visible at the apparent diameter (10.4"). The cloud activity was very interesting and prominent. We should enjoy even better views of the red planet in the upcoming months.
My custom 9-inch (23-cm) F/13.5 Maksutov-Cassegrain was produced for me by a friend (Michael Palermiti) and it is the finest instrument that I have ever used. The views of the Moon and planets through this instrument display high contrast and sharpness. The amount of detail that I note over the Moon and Jupiter, under good seeing conditions, are at times beyond my ability to render them. I highly recommend the Maksutov-Cassegrain for the Moon and planets.
The best of luck in your own observations of the Moon and planets.
Regards,
Carlos
