Double cluster with 160EDF and ST11000
Started by RolandC, 09/20/2005 09:57PM
Posted 09/20/2005 09:57PM Opening Post
This image of the Double Cluster was taken with my 160EDF refractor and an experimental telecompressor/corrector at F5.8. The attached image is reduced to approximately 1/4 of the original size of the ST11000 format. At that reduction, the stars became so tiny, that most of them disappeared on my computer screen. Therefore I had to try some techniques to get them to re-appear on the screen.
Normally one tries to get the tightest focus possible to get the prettiest picture, but in this case I actually had to defocus the image in Photoshop by applying a Gaussian blur to give the stars a bit of size so they would re-appear on the screen. On the original image, the stars had a FWHM size of 1.3 pixels, so theoretically when reduced down, they would have only 1/3 pixel size. This essentially means that they not only lose their size, but also most of their brightness when reduced. By blurring them, and boosting their brightness to the original levels, then reducing the image size, I was able to keep the colorful stars on the monitor.
This ST11000 is on loan to me from Ray Gralack for testing. I can see that it is extreme overkill for a typical computer monitor, but you should see what a 20" print looks like with full resolution. You have to examine it with a magnifier to see all the detail. I really like this camera, and have to think hard about whether I want to replace my trusty ST10XE. I thought that the ST11000 with its anti-blooming feature would be super slow to record stuff. I was basically wrong about that. This image consists of two 5 second exposures each of LRGB taken last night during a full Moon and somewhat hazy skies. Essentially a 10 second unguided image under poor conditions. Not bad at all.
Roland Christen
RolandC's attachment for post 26952
Posted 09/21/2005 12:51AM #1
Hi Roland,
That combination of 160mm unobstructed aperture, f/5.8 (with reducer)and large CCD chip is a dream come true! Give me that setup and an STL11k or KAF-6303E camera and POW I'm in heaven!!
I like the STL11k also in pretty much all aspects except that it is much less sensitive in Ha than the ST-10. Usually when I image in Ha with my ST-10XME I'll shoot 5-10 minute frames (f/7, 6nm filter), but with the STL11k I have to do 20-30 minute frames to get similar results. The STL11k (KAI-11000M) also has significantly more chip defects than the ST-10XE (KAF-3200E) and it also has more chip noise than the ST-10XE, thus making good processing techniques even more important.
I really like the excellent anti-blooming however, and that FOV -- WOW! The STL11k on my AP155EDF is truly wonderful -- that telescope handles that camera like they were made for each other! I had a special adapter made that connects my 4" field flattener to the STL11k's front threads thus getting rid on the STL's 2" nosepiece. The adapter connects to the field flattener via the bayonet ring just like your A1261 adapter does. It has a larger clear aperture at the CCD window than the 2" nosepiece so there is less vinetting. The custom adapter was designed to give me the proper distance from the field flattener to the CCD chip plane.
Post more images with that new setup if you can.
Tom Davis
Inkom, ID
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
www.tvdavisastropics.com
Posted 09/21/2005 04:51AM #2
That's a pretty strange looking image, Roland. The stars (the white ones anyway) all appear to be about the same brightness, giving the impression of a field of speckles rather than stars. It looks more like the result of manipulating the Photoshop noise filter than an astrophoto. Just my perspective as a space artist...
Joe Bergeron
Moderator, Astro-Physics Forum
