Ruben Tommasi
Andromeda Galaxy (M31)
Gamma Cygni and IC 1318 - Ha RGB
Started by jthommes, 08/24/2008 08:01PM
Posted 08/24/2008 08:01PM Opening Post
I am finding the DSLR is very good when you want higher resolution and wide field, but even after a spectrum enhancement modification, the level of sensitivity does present some challenges over that of a monochrome CCD.
This image is made with my Canon 350D DSLR. It is modified (Baader ACF for Ha emission line). I also used a Astronomik EOS Ha filter(13 nm) for an exposure set - so it is first light for me on the filter.
Full size image and exposure / processing details are here:
http://jthommes.com/Astro/DSLR/IC1318.htm
(be sure to click on the image or link for highest resolution)
Megrez II at f/5.4
Canon 350D (ACF modified) - one exposure set with Astronomik 13 nm Ha EOS clip
G11/Gemini
Guiding: C8 at 1350 mm FL, DSI Pro, Phd Guiding
I have a similar image with an Artemis285 (CCD) made in 2005 (Weaker processing skills back then...):
http://jthommes.com/Astro/GammaCygni_IC1318.htm
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
Posted 08/25/2008 12:42AM #1
Mighty fine image Jim. I take it you used a 48mm or similar Ha filter perhaps in the photo adapter or is this something that goes in the body in front of the ccd?
Kevin
Posted 08/25/2008 01:58PM #2
Sweet shot Jim... lovely widefield, great detail & colors!
Thanks for sharing! 8)
Posted 08/26/2008 03:16AM #3
Kevin, Ivan,
Thanks for the comments
Kevin,
The H-Alpha filter is actually an Astronomik clip that goes right in front of the DSLR mirror on the camera body. You can remove the camera body from the telescope using the 1/4 turn bayonet. That way you can do a Ha exposure, then dismount the camera, remove the filter and remount the camera for an unfiltered RGB exposure set. In this way the framing and orientation is preserved and your optical train is essentially undisturbed - of course refocusing is necessary without the filter.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
Posted 08/26/2008 12:21PM #4
Nice shot - really wide and detailed.
Darkness - typically 6.5+
Focus - JMI Smart focus
