Head of the Jellyfish
Started by jthommes, 01/23/2007 03:24PM
Posted 01/23/2007 03:24PM Opening Post
I have done a close up shot of the head of the Jellyfish - IC443.This was a composite of HA and RGB. The HA was used for Luminance and the RGB's were the color data of course. Full size image and exposure / processing details are here:
http://jthommes.com/Astro/IC443.htm
Camera was my Artemis285, Scope was my C8 at F3.3
I do have an earlier image in a wider field taken with a ToUcam:
http://jthommes.com/MiscAstro/Archives/IC443.htm
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
Posted 01/23/2007 04:18PM #1
Excellent image Jim!
Beautiful detail & colors! 8)
Posted 01/23/2007 05:42PM #2
Great image of the jellyfish! You did a masterful job of blending the Ha data.
Posted 01/23/2007 07:36PM #3
Well done, Jim.
A lot of people saturate the top of the 'head' of the Jellyfish, but you didn't.
I would have thought that 90 second subs for the RGB would be too short, but the color looks good on your image.
I especially like the subtle color shadings. Did that come just from the RGB data or did you blend some of the Ha data into the blue channel?
dan
Posted 01/23/2007 09:10PM #4
Nice 3D effect you have there, Jim! I haven't shot this object before, so I'm not sure whether that blue spot is real or not, but it does add a nice touch to this object.
Eric
Posted 01/24/2007 02:32AM | Edited 01/24/2007 02:34AM #5
Really lovely shot Jimmy. One of your best. You have a lovely colour balance on this object and it has a nice glow about it rather than the flat red that some Ha shots can give.
You can also add a bit of the Ha to the blue channel (about 15%).
That blue area looks good. I think a lot of nebulas have these O111 type blue areas that often get missed. The Lagoon for example has a lot of it surrounding it so does the Trifid.
Greg.
Posted 01/24/2007 06:14AM #6
...very nicely done, Jim!
very good colors and huge amount of details!
best
Dietmar
clear skies, guys!
Dietmar
www.stargazer-observatory.com
Posted 01/24/2007 02:21PM #7
Beautiful Image Jim!!
Thanks for sharing it.
Ciao
Luca
www.amun-ra.org
Solar Imaging Website
Posted 01/25/2007 05:36AM | Edited 01/25/2007 05:37AM #8
Thanks for the comments guys..
dan kowall said:
Well done, Jim.
dan
Greg.
Dan and Greg,
So for this image the color data comes the RGB exposures only. After luminance layering however, I did adjust the green and blue channels with a 18% subtraction of the HA (nebula only). I do this to restore the original RGB hue since the luminance layering tends the red toward pink or salmon.
Greg, I agree that blending the HA into red can take away the tonal subtleties - I didn't blend any HA into blue (interesting thought).
Dan, So in the processing, I did desaturate the head so the LRGB would work well on the nebula. But I am convinced that due to the short RGB subs, errors at the low intensity signal levels can (and did) creep in.
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
