james carter
North American Nebula NGC7000
Which mount should I buy ? EM10 USD, GP-DX + SkySensor2000 or Losmandy G11 ?
Started by moutinho, 10/11/2005 02:04AM
Posted 10/11/2005 02:04AM | Edited 10/11/2005 04:03AM Opening Post
Hi,
I need a decent mount for astrophotography. I have noticed that the following mounts have very similar prices used:
-EM10 USD
-GP-DX +SkySensor2000PC
-G11
Which one should I take ?
Andre
Posted 10/11/2005 02:49AM #1
Yes, first reaction is the G11. But one other consideration is if you travel to your imaging site or your more or less permanent. I believe the the G11 is the heaviest of the three. My buddy has a G11 - great mount, I'm not sure I could handle the weight (I'm kinda small).
Jim Thommes
Mak-Newt 152 mm
C8
Megrez II APO
Zenithstar 66 mm APO
G11/Gemini
ST8300M
Artemis285 Camera
Canon 350D DSLR
http://jthommes.com/Astro/
Posted 10/11/2005 03:43AM #2
What scope/scopes are you considering? The G-11 has more load capacity than the others, and as such, allows a wider range of possible scopes. Here is a link to my astro gallery. Nearly all the images were taken with a G-11/Gemini.
Cheers,
Tyler
http://www.utahastronomy.com/geomorph
Posted 10/12/2005 12:29AM #3
Have you looked at the MI-250? It's a little more in price but substantially more stable, accurate, and the best money value for a precision mount. It is superior to the G-11 in every way (design and support). I have owned one and it was excellent. On the other hand I have owned a G-11 also and it was good, but it took quite a bit a work to get the worms to mesh properly to remove the slop. I am not criticizing the G-11 -- only my opinion from using both mounts.
http://www.mountaininstruments.com/
Tom
Starsearch Observatory
Lat 42N 47' 00" Long 112W 10' 47"
Elev 1752m
www.tvdavisastropics.com
