4-inch Mars 10/02 - Syrtis Major/Hellas Area
Started by ronbee, 10/03/2005 03:17PM
Posted 10/03/2005 03:17PM Opening Post
I can see now that seeing is the medicine that cures all. Seeing is the "super computer" that cut processing time down to almost nothing. Usually, I'd see Mars looking like an inflating/deflating baloon in the capture, but not hardly this morning!
Well, here's the result. I'm also 99.99% certain that I've reached the limit of the 4-inch aperture this morning (and I believe larger aperture would have done very well with the seeing this morning).
I tried one capture at insane f/86 , which is 8800mm focal length for a 4-inch aperture! As you can see, the image is kind of unsharp. Well, I'm still a newbie Sith imager, so I don't know any better :-). The image was so huge that it took a large portion of the capture 640x480 screen. Since my mount does not track well, I had to manually keep Mars from exiting the screen since it was drifting pretty fast at that image scale. The 4-inch aperture was also limiting in that I had to crank up the gamma to even see the image clearly! Also, focusing was excruciating painful, so much so I almost threw in the towel.
I wondering how you guys with large aperture and huge image size could keep the image from drifting out of the capture screen? Did you use extremely accurate mount like for long exposure DSOs? Precisely polar aligned?
Ron B[ee]
PS - I was so full of sorrow I didn't prepare to image with my 5-incher that morning instead :-(.
ronbee's attachment for post 27253
Posted 10/03/2005 05:18PM | Edited 10/03/2005 05:18PM #1
Another fine set of images from Mr.Bee and his 4" APO...
F/86? Are you nuts? wink 8) .... you might be the first one to push the 4" barrier to such levels... wink
Thanks for sharing Ron, and keep it up!
Posted 10/04/2005 07:03AM #2
Great shots. I can't wait to see what the 127 will do on a night with similar seeing.
Regards
Peter
