I spent the last two nights wrestling with Jupiter at 24 degrees. On May 30 the seeing was quite good overhead - might be worth spending some time working with this data. This morning the seeing was not as good and the transparency very poor, so I set the 10" mak at its native focal ratio (f14.6). If you use your imagination you might see just a hint of the detail shown in the gorgeous images from Chris, Mike and Anthony.
L(R+G)RGB prepared from about 250 frames each R, G&B recorded with the DMK21BF04 camera.
best wishes,
Alan
best wishes,
Alan
Alan Friedman
