Comet 17P Holmes Jet structure
Started by stefan lammel, 10/30/2007 12:56PM
Posted 10/30/2007 12:56PM | Edited 10/30/2007 05:53PM Opening Post
Hi all,
This is a first for me, usually my scope is pointing at the Moon but who could resist this spectacular target! smile
Turning the wavelets up to eleven has brought out some structure in the coma, the image is a composite of 2 versions of the same image. The gross over-processing was the only way I could tease out this detail, I will try some other less aggressive techniques and post here if it works out, any suggestions welcome...
http://www.pbase.com/slammel/image/88113343/original
http://www.pbase.com/slammel/image/88113321/original
Both images stack of 440 exposures 3-6 sec, green & no filter, Infinity 2-1M & 10in f4.8 Newt. 29-Oct-07 22:30UT.
Regards,
Stefan
stefan lammel's attachment for post 39448
[COLOR="Navy"]
Stefan Lammel
[SIZE="Small"]
http://www.pbase.com/slammel/moon [/COLOR][/SIZE]
Posted 10/30/2007 05:56PM | Edited 10/30/2007 10:52PM #1
Pete Lawrence has suggested the Larson-Sekanina filter which is frequently used by comet imagers to bring out the jet detail. I discovered the demo version of Astroart has this filter and this is a screen shot of the result with the default settings, what an amazing filter! I wonder if it is available elsewhere or maybe I will have to fork out for the full version if I get into this...
Thanks Pete! smile
Regards,
Stefan
the squiggles at top right are from a couple of hot pixels - must learn to use darks...
stefan lammel's attachment for post 118061
[COLOR="Navy"]
Stefan Lammel
[SIZE="Small"]
Posted 10/30/2007 07:58PM #2
Hi Stefan -
Nice work on this. The moon will wait!
cheers,
Alan
Alan Friedman
Posted 10/30/2007 08:28PM #3
Sweet stuff Stefan! 8)
Thanks for sharing!
Posted 11/01/2007 12:35PM #4
more from 30th...
stefan lammel's attachment for post 118106
[COLOR="Navy"]
Stefan Lammel
[SIZE="Small"]
Posted 11/01/2007 12:37PM #5
and 31st, here you can also see that it appears to have slightly expanded...
- as you can see I still have problems with the hot pixels despite using a dark frame in Registax. It looks like it doesn't apply it to all the frames or maybe I'm doing something wrong?
Stefan
stefan lammel's attachment for post 118107
[COLOR="Navy"]
Stefan Lammel
[SIZE="Small"]
