Is it better not to have IR cut filter on planetar
Started by gregbradley, 02/14/2009 10:14AM
Posted 02/14/2009 10:14AM Opening Post
With DSLRs they perform better without the restrictive UV/IR cut filter.
Is this true with planetary cams?
I see the Imaging source cameras often have theirs removed. Is this a special
feature that other cameras don't have?
Greg.
Posted 02/14/2009 01:53PM #1
If you use filters for RGB on a mono camera, most of them have IR cut built in. They are usually much better quality than the one on the camera, so personally I'd remove it and let the filters take care of it.
Paul
Paul Maxson
http://www.sunspot51.com
Posted 02/14/2009 03:25PM #2
Greg.
People remove these filters because they are of crappy quality. You most certainly want an IR block filter ahead of the chip, though, leastways unless you like strugglin' with hot pink planetary images.
wink
Uncle Rod
Time on your hands?
Posted 02/14/2009 05:29PM #3
Greg.
An IR/UV cut filter more important with refractors and CATs than with reflectors. Even Apo lenses cannot image UV & IR properly, and these will blur the image because the CCD is sensitive to the out of focus wavelengths.
Jim McSheehy
Posted 02/14/2009 09:27PM #4
As has been said you can use IR blocked RGB filters for collecting color data or for narrow band imaging. But also a camera that is not blocked for IR (such as the DMK series from the Imaging Source) can image in IR wavelengths with an IR pass filter.
cheers,
Alan
Alan Friedman
